  New Posts New Posts RSS Feed - Strut bushings
Strut bushings
JDD33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDD33 Quote  Post ReplyReply Direct Link To This Post Topic: Strut bushings
    Posted: March-24-2014 at 11:51pm
Thanks Tim!
Old school goin back to school!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2014 at 11:26pm
John, flush in front and rear will be perfect on the new 2-piece bushing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDD33 Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2014 at 10:55pm
So my new to me 1987 Ski Nautique needs a little maintenance, there is some slop in the strut bushing.
I dropped the rudder, un did the coupler, pressed out the shaft and removed it.
Everything look to be in good shape and I think that it's never been apart, the safety wire was still on and the coupling needed some serious encouragement to split. The packing is definitely spent on both the shaft and the rudder. Oh and the boat has 1004 hours on it.
So my question is...
The strut has S-19 stamped on it and the area the shaft passes thru is 6 7/16" long
The brass and rubber bushing is 6" long
My new XPC Vesconite bushings are 2 piece and a total of 4"
So... After I remove the original bushing do these 2 get pressed in from either end with a space in the middle? Or do I need to get a 3 rd bushing to make the new bushings the same length as the old?
Thanks for the help, John.
