Trans oil cooler |
Author | ||
gR@HaM
Platinum Member Joined: May-01-2012 Location: UK Status: Offline Points: 1265 |
Posted: April-15-2014 at 4:49am |
Thanks for the info shall make sure I plumb them in the correct way round
'82 Ski Tique
Top hose from the trans is out. Bottom is the return. Yes, it's important to counter flow any tube and shell heat exchanger. It keeps the delta T to the max so the efficiency with the heat lost/gain is the greatest. |
baitkiller
Old argument and it has been proven many times that a tube cooler works better with counter flow rather than parallel flow. It is a mistake often made but never serious on these little boats.
Graham FYI the pressure side of the gear comes off the top.(that hump on top is a combination spool valve and pressure regulator) Return is at the bottom but I'm guessing you knew that. |
lakedog55
I did not either. But it is supposed to cool better
Lakedog55
gR@HaM
Wow never even considered that... |
'82 Ski Tique
gR@HaM
That's exactly what I was after, yes I have a new bracket from skidim.
Thanks |
'82 Ski Tique
lakedog55
Remember your lines go on so the flow of tranny fluid is opposite the water. I can't remember which is out and which is in on tranny. Someone will be along. If not the reference section had it.
Mike |
Lakedog55
ny_nautique
Platinum Member Joined: June-01-2011 Location: Albany NY Status: Offline Points: 1215 |
- Jeff
1999 Ski Nautique |
gR@HaM
Thanks presumably that second bolt up in the photo..
'82 Ski Tique
lakedog55
Bell housing
Lakedog55
gR@HaM
'82 Ski Tique
