Fuel pump lost prime |
kytom2
Gold Member Joined: July-25-2007 Location: Maysville Ky Status: Offline Points: 698 |
Posted: May-15-2014 at 12:21am |
Do you have a fuel shut off valve in your fuel line? If so could it have gotten turned to off?
jimsport93
Platinum Member Joined: February-20-2008 Location: Alpharetta Ga Status: Offline Points: 1750 |
Had a strange thing happen to me this past Sunday. Boat cranked and then died after my wife was backing her off the trailer. Cranked and cranked. Would not restart. Thought about my Pro Tec set up. Turned out that my spin on fuel filter/water separator had vibrated loose and was sucking air and loosing prime ( guess I had not over tightened after I had to put it in a vice to get it off last time). First time that has happened to me. Got her started after tightening it up.
Chris9304
Newbie Joined: February-02-2014 Location: Orlando Florida Status: Offline Points: 14 |
thanks i went ahead and changed the fuel pump out as i have a full tank of gas and also had pressurized the system with no luck. of course i had a dead battery from the last time i messed with it so it is currently on the charger and will update after the next test
backfoot100
+1 You gotta make sure that gas is even getting to the pump first. If you ran this dry and now the fuel filter/water seperator was changed, everything from the fuel tank all the way up to the fuel bowl is now potentially dry. I would fill the fuel bowl with gas before starting so as soon as the engine fires it'll charge the complete fuel line before the bowl runs out of fuel. Just like you would have to do the first time you started up an engine after a rebuild. |
Eddie |
JoeinNY
Put a vacuum pump on the fuel line, a brake bleeder available from the harbor freight should do it. There is an anti siphon valve on the top of that tank, which should be checked. If it were me I would first take that fuel hose off the pump, if it were full of gas then its not a problem with the pump, if it isn’t full of gas blow through it either with your mouth our a little compressed air, it should allow air through. If it does then move to the vacuum pump or try an external tank to see if the boat will run on that. But I wouldn’t replace the pump all haphazard like until I was convinced that the tank/antisiphonvalve/hose assembly was all acceptable.
KRoundy
Sounds to me like you need a new fuel pump. That may have been the problem all along.
Chris9304
any new tricks i have replaced the water separator validated that everything else vent pipe etc is working but still not getting the fuel pump to prime. any other thought before i put a new fuel pump in it?
thank you Chris |
gun-driver
You emptied your fuel line when you ran it out of gas. Pressurize your tank with an air compressor while someone cranks it.
Or you can disconnect the fuel line after the filter then pressurize untill you get flow. |
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
Pull the fuel line and see if the pump is pumping fuel. Turn it over it should squirt so be careful
This is the life
Chris9304
If I pump the throttle no fuel is being squirted from the needles. If you pour fuel into the carb it will start. It did run after the overheat but in the process of finding all of the cooling issues it ran out of gas. It is an 86 Nautique 351 motor. Boat has spark and will run just no fuel delivery. I have a lot of experience with carbs and fuel systems but less with engine driven fuel pumps
backfoot100
More info would be nice.
How are you so sure it's the fuel pump? Sure you have spark? What about compression? It overheated. How bad are we talking? Overheats can cause all sorts of issues that may manifest themselves long after the fact. Having it running after the impeller and thermostat change is a good sign though. |
Eddie |
phatsat67
More info? Boat? Fuel coming out of the accelerator pump nozzles when you pump the throttle? Symptoms?
IAughtNaut
Grand Poobah Joined: August-22-2010 Location: TN Status: Offline Points: 2568 |
Did you flick it?
Chris9304
Guys I have lost prime to my fuel pump and unable to get any gas to pump into my carb. This is after my brother in law overheated my boat. Don't think they are related as I did get it to run after I changed the thermostat and impeller. Thoughts on this would be great
