  New Posts New Posts RSS Feed - 76 SN stringer repair
Family76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Family76 Quote  Post ReplyReply Direct Link To This Post Topic: 76 SN stringer repair
    Posted: April-25-2014 at 12:05am
Both main & secondary stringers will be douglas fir as well as the ribs, floor will be marine grade plywood, see picture above of doug fir and plywood.
As for the materials needed (resin type, glass type, number of layers on each structural piece) that is the question I do not have the answer to. I have very little knowledge of fiberglass and/or resin in this application of a SN stringer replacement. Hope to get some guidance in this area, please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2014 at 9:03am
You need to first decide on your structural configuration (stringers, floor, ribs/bulkheads, foam, etc), and then decide your layup schedule (resin type, glass type, number of layers on each structural piece) before you can come up with a detailed material list. Sounds like you're puting the cart before the horse?
Have you done this yet?
Air206 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2014 at 12:07am
What Gary means is use the following syntax on Google:
Site:correctcraftfan.com "stringer material list"
That's the best way to search the site - Not the CCFan search feature.... Hope that helps....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2014 at 11:53pm
Google correct craft fan stringer material list. You need to do way more grinding on the bilge to get that gel removed along side those stringers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Family76 Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2014 at 11:39pm
Finally got a couple of pictures loaded. Not the best quality but hopefully you can see them. Secondary stringers out and one main stringer is out. Lumber has arrived. So back to my original question, what do I need for fiberglass, epoxy, CPES etc.. to get started bedding the main stringer? I have read several threads on stringer replacement but few have a materials list for these items or much detail of the fiberglass process. If there is a good example please let me know. I do not plan to rebuild with foam. Any help would be appreciated,
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 9:53pm
IAughtNaut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IAughtNaut Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 8:06pm
I'm not so good with geometry but if IA is Iowa then the first thing I would do is PM storm34 and pick his brain...if anyone knows where to get stuff in Iowa its him.
bring the ruckus
2000 Pro Air
Smithfamily View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smithfamily Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 7:53pm
Good luck with it!! Pictures??
Js
Post Options Post Options   Thanks (0) Thanks(0)   Quote Family76 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 2:46pm
Another stringer replacement thread on CCF, maybe not exciting to anyone else but I need help & this is the best place to get it! I have been reading posts on CCF for years but this is my first posting.
A little history first: this 76 Ski Nautique was purchased new as a promo boat from Hartwick Lake Marina in Delhi IA by my wife's family & has never been resold. Lake Delhi is gone for the moment (google Lake Delhi Dam breach) which gives me an opportunity to restore the SN since my wife made it very clear that the boat is not for sale and it never will be! That said, let the restoration begin.
Today I have the 350 Chevy OMC out and on engine stand, the floor is out and down to one main stringer left. Douglas fir order arrived Thursday. Now for my question, where to find the most accurate materials list for epoxy, fiberglass, tape, CPES, etc. And where to order? Seems like iplan has a good list in his Stringer repair 1985 2001 ski nautique thread. As of now the plan is not to use foam.
I would like to get an order out this week so any advice would be appreciated.
