excalibur and vortec heads compatibility |
mark c
Gold Member Joined: May-09-2012 Location: Massachusetts Status: Offline Points: 534 |
Posted: May-12-2014 at 2:37pm |
The big issue with "Vortec" heads is that every engine small block and V6 engine GM made in the late 80's to mid 90's started carrying the term VORTEC on them when in reality the L31 heads are the only really good vortec heads. Heck my 4.3L 6 cylinder engine in my Jimmy was labeled vortec and while the 4.3L engines are great little 6 cylinders that you can't kill easily, I would not rate them as performance engines by any means. Some people say the L31 Vortecs are the best flowing heads GM ever made. Don't know about that as I stick to the earlier engine configurations.
baitkiller
Also you cannot tell from the valve covers. Normal heads used the center bolt covers for a few years. I have them. Look at the intake bolts. They go straight down, not angled and I think there is 8 not 12.
Thanks for the casting numbers Mark. Thats handy stuff right there. |
malibud
Gold Member Joined: July-08-2009 Location: north carolina Status: Offline Points: 613 |
Thanks a bunch ... That's what I needed to know
mark c
You sure of that casting number? 14102198 does not appear to exist, 14102191, and 193 are vortec TBI swirl port heads made from 87 to 95 and aren't worth the price to scrap them. The 191's are 76cc chamber heads with 1.88/1,5" valves, and the 193s are 64cc heads with 1.94/1.5" valves. They make good low RPM torque and make OK power up to about 4500 RPM, but thats about it. Basically they are good truck motor heads. The 12559062 and 10239906 castings are the L31 true Vortec heads.
malibud
That's what I got . Can I replace one right ? Are all vortec heads the same as far as compatibly ? Like ford gts ? Found some at a decent price
mark c
Four valve cover bolts right down the center of the valve cover, as opposed to two on each side (top and bottom)on the valve cover flanges |
malibud
8 bolts for intake = vortec rights ?
malibud
How do I tell if it is a vortec ? I was assuming it was since it was an excalibur 343 HP (and 2003 ) I thought vortec came out in 1996 so couple of years for boats to catch up? thanks
baitkiller
You may not use only one. The intake manifold bolts are different.
If your engine is non Vortec you will need a new intake manifold as the bolt patter is different. Not a bad problem to have is will make a bunch of horse powers for little effort. Did you find a good deal on those heads? Its on my to-do list. |
malibud
will these heads work with a 2003 excalibur from a 196 nautique
vortec TBI swirl port heads they have 14102198 stamped on the inside rebuilt with 2.02 valves (intake) Can I use just one (I have a cracked water jacket) and really dont want to use JB weld. thanks Dan |
