Hull Repair |
pmurray315
Newbie Joined: January-03-2014 Location: Atlanta, GA Status: Offline Points: 20 |
Posted: May-15-2014 at 5:25pm |
Thanks for the referral, I will give him a call today. Thanks again!
Toertel
Gold Member Joined: August-26-2013 Location: Atlanta Status: Offline Points: 775 |
Patrick,
Since it says ATL on your details, I assume a fiberglass guy on Lake Lanier might be OK. A tree just fell on my boat a few month ago and I used Chris (http://cgmarine.net/Home.html) for mine. He did a good job on mine and had other CC's in the shop at that time. If you go to him, let him know I sent you |
1994 Sport Nautique
pmurray315
I am looking for someone that can do some fiberglass/hull repair on my '89 SN around Clemson, SC. I purchased this boat a few months ago and have discovered some water leak around where the shaft exits the bottom of the hull. From what I can tell, there was some (sloppy) repair work done on this boat at some point, and I would like someone to take a look to see if they can patch or reinforce the area. I would do so myself, but given the location of the deterioration the shaft most likely needs to be removed, and I don't feel comfortable doing so.
Thanks Patrick |
