Seat rebuild recommendations |
audiodude
Senior Member Joined: November-19-2012 Location: Badin Lake Status: Offline Points: 308 |
Posted: June-03-2014 at 10:05am |
This was what I used. Sorry if I confused the issue with the wrong name.
the upholstery guy said he uses it all the time. I doubled up the pieces. In my '89 there seems to be good support under the seats so I haven't has any flexing issues. |
2000 Ski Nautique 1989 Correct Craft 2001
In the words of Milton Berle: "You can lead a man to Congress but you can't make him think" |
Id be curious to know exactly what you used... got any scraps left that you can post a picture of? The 2 composite materials Ive seen suggested for seat base use are HDPE (high density polyethylene, like King Starboard) and XPCV (expanded polyvinyl chloride like Sintra Board). Correct Craft uses the latter in their seat bases. Both are supposed to accept staples.
The problem with XPVC is that its not all that strong... which is fine on a modern interior where the seat bases are well supported by the frames. Most times theyre 100% supported by glass structure, other times the spans are very small. I have read numerous accounts online of HDPE bowing or warping due to age, temperature, or weight. I'd be a little nervous using it alone if the spans are large. A 70's interior has large unsupported spans- most notably on the observer seat, where 2 aluminum frames (2" wide) carry the full load over a 30-36" wide seat. Lots of opportunity for flex. Many structural composites, like coosa (which is foam and fiberglass based) will not hold staples well- making it a poor choice to wrap upholstery around. I think a hybrid seat base made of a 3/8" layer of coosa (glassed on both sides) plus a 3/8" layer of XPVC would be pretty much ideal from a strength and longevity standpoint. The downsides would be cost, and complexity. |
audiodude
When I had my seats re-done the guy at the upholstery shop suggested polyurethane? board, it's white and comes in a 4'x8' sheet, which I bought at HD. It's 3/8" so I doubled it up. He said it hold staples well. So far so good but it's only been a year. It wasn't cheap I think I paid around $100 for a 4'x8' sheet.
No joints on a basic 70's interior, Pete.
I'm not convinced cpes and epoxy are a better way to go on seats vs. treated ply. One day I plan to put together a better solution than wood, but it will probably involve 2 different composite materials sandwiched together- One for strength, one for staple retention. It seems there is no magical material that does both well (and doesn't rot). |
I agree that the 5/8 would be fine and the 3/4 would be overkill. Besides the CPES and the epoxy, I would suggest a layer of glass tape (3") at the joints. Be careful with the SS fasteners you use. Do not use the cheap ones for decking you find ate HD. They are 400 series and will rust!!
Orlando76
So I spent the rainy day researching CCF and the web on tips and threads for seat rebuilds, which lead to many side tracks. In 2 weeks I plan on rebuilding my seats and reusing the same good upholstery. I guess exterior grade plywood is still the best choice? I'm thinking 5/8 but my dad says we used 3/4 20 years ago. I'm thinking 3/4 is overkill, no? I was going to CPES then epoxy over that. I know about as much in resin and glass as I do brain surgery so I'm just doing this as a practice. Of course Im using SS hardware and need to re-order SS staples and want to order everything so it'll be here when I need it.
