  New Posts New Posts RSS Feed - Vibration
Vibration
*mtrbtr* View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote *mtrbtr* Quote  Post ReplyReply Direct Link To This Post Topic: Vibration
    Posted: June-17-2014 at 12:09pm
Yep sure feels good to get it fixed and learn something in the process. (Not sure how I got that double post up above though)
2006 SV 211 (sold) went to the dark side
97 Sport Nautique (sold)
89 PS 190 (sold)
05 Four Winns H180 (sold)
89 Four Winns 180 Freedom (sold)
75 MFG (sold)
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2014 at 12:49am
Hurrah! Well done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote *mtrbtr* Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2014 at 5:15pm
Just to close this out. I checked and noticed that my shaft packing was very much in need of adjustment. Repacked the shaft and rudder and added new acme 654 prop and no vibrations.   I haven't had a chance to put the prop back on to notice any differences.
89 PS 190 (sold)
75 MFG (sold)
Post Options Post Options   Thanks (0) Thanks(0)   Quote *mtrbtr* Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2014 at 5:14pm
Just to close this out. I got a new prop but also noticed that my shaft packing was very much out of adjustment. Repacked the shaft and rudder and new acme 654 prop on and no vibrations.   haven't had a chance to put the old one back on to notice any differences.
89 PS 190 (sold)
75 MFG (sold)
Post Options Post Options   Thanks (0) Thanks(0)   Quote *mtrbtr* Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2014 at 2:03pm
No zerk on this one.   I will repack it all this weekend and grease it all up. Plus getting the prop will hopefully make all this go away. Just hope its not the shaft.
89 PS 190 (sold)
75 MFG (sold)
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2014 at 1:59pm
Have you greased your rudder recently? It should have a little zerk fitting on the rudder port. I've noticed that seems to remove some of the play.
Or course, if you're going to repack it anyway, the extra grease might be a bigger mess for you to deal with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2014 at 12:32pm
I'd work on your loose rudder first. Something is not right. I don't think you should be able to move the rudder side to side at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote *mtrbtr* Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2014 at 11:34am
I agree with you. I just was hoping to not have to order a new prop. There is one prop shop in the whole state of Montana, not anywhere near me. I am planning on repacking the rudder this weekend and bit the bullet and ordered a new prop. When I get the new one, I will send the old one off to have it balanced. $$$$$$
89 PS 190 (sold)
75 MFG (sold)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2014 at 7:51am
Jonathan,
You will not be able to tell if a prop is out of balance just looking at it. A prop shop needs to set it up and check it. The other issue may be the shaft itself. A dial indicator will tell. .003" is the max run out. I have seen shafts turn easy but due to the cutlass being worn. Gave you checked your alignment?
I do not think it's your rudder. Re-pack the port and see if it makes a difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote *mtrbtr* Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2014 at 3:45am
First trip out after replacing the steering cable in my 97 sport I noticed vibration at high rpms.
After doing some reading I thought it might be the prop but my prop looks perfect. I turned the prop by hand out of the water and see/feel no issues or binding there. However the rudder has a lot of play both side to side and front to back. I am sure it is time to repack it anyway, but could the play be causing the vibration?
89 PS 190 (sold)
75 MFG (sold)
