oil drain |
jon4pres
Senior Member Joined: September-19-2005 Location: United States Status: Offline Points: 275 |
Posted: April-21-2006 at 9:56am |
BKH mine had no kind of hose. The way I did it really didnt cause much of a mess at all. It took less than a minute and 4or5 rags to get all of th oil that didnt run out the drain hole.
Chavonbravo. I hope you are kidding. I am definetly not a tree hugger but I would hate to see our lakes become more polluted. |
chavonbravo
Newbie Joined: November-01-2005 Status: Offline Points: 35 |
I like to change my oil in the lake as well, that way I can just dump the old oil overboard...
bkhallpass
You may already know this, but I'll go anyway. Many of the boats ( and all of the new boats), have a hose connected to the pan where the plug would go. It's a couple of feet long and has a screw on cap on the end. You simply remove the boat plug, put the hose through the hole and drain the oil through the hose into a bucket below the boat. FWIW. BKH |
Livin' the Dream
JEFF KOSTIS
JIH, is that the same pump used to syphon the gas??? We will know who it is if people start loosing motor oil or gas!!! Jeff... |
stang72
J-I-H...I used to pour mine down a mole tunnel! Now that I ran the mole out, I'm going have to sneak out at night and give it to the folks next door...can't stand them anyway!When they start digging in the garden, it will be like hitting black gold, Texas tea...time to move to Beverly Hills...movie stars...swimmin pools!
David F
IMHO, the drain hose is still the way to go if you trailer your boat. You just cannot get in a hurry when changing oil. I usually start the oil draining and then go work on another project and come back to complete the oil change later in the day. Oh yea, it helps to remove the oil cap when letting it dain.
jon4pres
I am way out of the loop here. I have only changed my oil once and it didnt have any kind of hose so I just ran it down into the hull and let it run out of the drain hole. I figured that is what how you were supposed to do it since it worked so well. After it ran out I just wiped up the extra oil with a couple of shop towels.
I know I am a new boat owner. I might look into one of those pumps though. |
The Lake
I bought a $20 pump at a marine supply store; it takes about 30 minutes to pump out 7 qts. I also use it to change the transmission fluid. It has a small tube on one end to go in through the dip stick hose.
2_Nautiques
Senior Member Joined: March-22-2006 Location: United States Status: Offline Points: 251 |
I got tired of changing oil on the lift so I switched to synthetic oil. Manual says to change oil ever 50 hrs, here in Ohio I get about 80 to 90 hrs a season. So I just change the oil in the fall when I winterize. Drop the hose thru the hull and let it drain for a day or two. Not alot of difference in cost if you consider two oil changes to one.
Jim_In_Houston
I suck mine out with a pump that looks like a volley ball. It works great if the oil is warm but man does it suck (or doesn't suck) if the oil is cold. Yep, I can get out almost all of the oil. Sometimes you have to jiggle the hose a little to be sure it is setting in the bottom of the pan. The nice thing, for me, is that I can change the oil with the boat in the water. IT's also nice because once you get the oil out you can run the container to the auto parts store to dump the oil. My neighbors got tired of me dumping it on their property late at night. I don't know how they figured out it was me..
danman
Groupie Joined: February-04-2004 Location: United States Status: Offline Points: 56 |
I was wondering if anybody on this forum was pumping or sucking their oil out through the dipstick tube when changing their engine oil, and has eliminated the sh**y drain hose. If so, How well does this work? Is there a small enough hose provided to snake down the dipstick hose? Does it get ALL old oil from the pan?
I am fet up with my drain hose. Sometimes it drains well, others it is slow. I replaced the hose last year, and now it is leaking oil where the rubber meets the brass end (crimp). Happy Ski Season! |
