Dirty Bilge |
Author | ||
tjca77
Groupie Joined: April-29-2014 Location: Dunwoody Status: Offline Points: 54 |
Posted: August-07-2014 at 7:23pm |
Like a fool I bought some Starbrite Bilge Cleaner right after I bought the boat. Doubt I can return it, so I will probably use it this time around, and keep the Dawn in my bilge and in my Wileys.
DrCC
Super Clean works even better on nasty bilges, BUT don't use it for binding slime unless you need your feet exfoliated.
lakedog55
Dawn works great and is also handy to slip on tight bindings.
Lakedog55
Yea Pete plus you can charge more for service
Yes and the reason 2 cycle engines are on their way out. Still, they didn't do much damage. |
MustangMadness
Senior Member Joined: April-15-2014 Location: Seacoast NH Status: Offline Points: 114 |
Just a brief note here to remember the waters that make up our wonderful playgrounds.
What ever you decide.. |
I like a 6' beam on a small lake... My Muscleboat
1975 Mustang 225 307RH |
Tim D
Castrol super clean, that purple stuff.
Tim D
Orlando76
+1 but I found a dose of tide or any other laundry detergent does slightly better. |
This does work. |
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
Run with a few squirts of Dawn in the bilge
This is the life
tjca77
Hose replaced this weekend and this fixed the leak. I used a 13.25 inch hose from skidim, it fit perfectly. Easy to access the connection to the transmission cooler. Pulled the engine box and floor access to get to the fitting on the transmission. Lucky to have dad in town to help. Sucked the old fluid and put in New while we were at it. Went skiing on Sunday and she ran like a champ.
tjca77
I am going to replace the hose, have a new one on order, hopefully it isnt to bad getting the old one off and the new one on. Thanks for the advice.
cadunkle
Groupie Joined: August-17-2012 Location: NJ Status: Offline Points: 66 |
I would fix the leak if it's as easy as a hose and doesn't need to pull the engine or trans. Clean the hose well to be sure it's the hose weeping through. Spray with brake cleaner and wipe with rag until it doesn't turn rags red/oily. Could very well be the inner rubber of the hose has failed and is weeping through the woven exterior. I hate oily bilges and especially making an oil slick when the bilge runs. If it's an easy fix like a hose do it now, if you gotta pull the engine or trans save it for winter if it's only a small leak.
tjca77
Finally made it to the boat today, fittings are tight. The hose itself seems to bleed transmission fluid, not much, but you can definitely see it when wrapping a paper towel around the hose. Don't want to replace it if I don't have to. Should I worry about it?
MustangMadness
Start by making sure all of the fittings are tight
tjca77
Should the hose be damp with tranny fluid? Is this just a sign that the hose needs replacement?
TX Foilhead
Red is tranny fluid, that hose is just a standard hydraulic hose and most any auto parts store should be able to make one.
tjca77
I have a 2000 air nautique direct drive, gt-40 with @ 600 hours on it and have been chasing some fluid leaks in my bilge. This is my first inboard, I grew up with and i/o and am trying to learn the ropes. Here is a picture of the dex I find, in the same spot each time I run the boat(unfortunately only once a week). Check out the small drop next to the pump. So to help find where it was coming from I put 3 small plastic plates under the tranny. I missed the tranny drip, but caught some oil. I have no idea where this came from. I should mention I changed the oil back in May and the dip stick shows full each time I check it when I take it out. When I check the transmission fluid I think it shows full.
So after feeling around the bilge, I think the transmission leak is coming from the hose in the last picture. The hose is moist with dex especially close to the tranny end, I am not sure if this is how it should be or if the hose needs to be replaced. The boat runs great each time we take it out. Finally got the wife up to speed and she can pull me on the slalom Just want to make sure if there is an issue I take care of it before it becomes a larger problem. Thanks, TJ |
