  New Posts New Posts RSS Feed - Wanted: 60's/70's trailer jack
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Topic: Wanted: 60's/70's trailer jack
    Posted: September-08-2014 at 11:58am
   With Decal.....
66 Skylark
93 SN
If you're not living in NC, you're just camping out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2014 at 2:40pm
Taa-Daa !!
66 Skylark
93 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2014 at 11:56am
Local places may have these also Gary..
Northern Tool
Northern Tool-- more OEM look
66 Skylark
93 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2014 at 11:46am
Marty, I say go for it! I'd buy at least one. Might want to nail down a brand/model of jack in case you want to make more in the future!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2014 at 11:29am
Another Jack
Yes Gary-
Also what Tim said about trying to replicate the OEM look. For me fabbing up the plate- with the slip over pipe- wouldn't be that hard. Getting a foot(wheel) then would be about another $10.
66 Skylark
93 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2014 at 11:23am
Gary, I would imagine that the eBay one is close enough as far as dimensions go. There are only a handful of options that look sort of like the old ones. If the throw is too short, put a block under the wheel!
New jacks installed on the outside of the frame rail certainly do twist the frame (as evidenced by the lean). The further they are from the center line, the more they twist. If you want to eliminate this, you can put the jack on the inside of the frame as far forward as possible- you just lose the ability to swing away.
If anyone is going to bother recreating the original look, it's going to be mostly for aesthetics... might as well go all the way!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2014 at 11:16am
Would not fool you but at least they would work,I swear that the swing away one I have makes the trailer lean. So is it confirmed that the ebay one has the same diamentions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2014 at 10:59am
You won't fool me, Marty- but don't let that stop you! To really recreate the original look, you'd want to weld that new bracket onto some tubing and install that over the body of the jack, and then weld it on. You'd have to cut off the old bracket too, of course... Probably a few man hours in that project!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2014 at 10:25am
Mr. Starr,
These OEM CC Jacks are roughly 23" in height and have about a 15"-17" travel. The plate that it's welded to that bolts on the trailer is roughly 5" x 7" x 4".
I just might try and get a couple then fabricate the plate- and say- "WOW" Tim- look what I found !
66 Skylark
93 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2014 at 8:42pm
Tim can you get the measurements off of yours like they did in the ebay ad so we can see how close they measure up? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2014 at 12:25pm
Yeah, those would work fine and look ok once you add a custom bracket... The CC trailers in question predate the standard a-frame mount pattern, so you can't use one as-is. Not a bad back up plan if I can't find a few more originals! Still looking for a few, not in a huge rush.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2014 at 12:08pm
Tim--
As you say- these might be hard to find...
THESE might be a decent replacement...
66 Skylark
93 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2014 at 3:04pm
I recently acquired this jack from dangerwill and I sure do like it... I have 2 or 3 more trailers from the late 60's and early 70's that would look good with one of these as well. If you have one laying around, functional or not, please let me know. If you have one installed and you're indifferent on originality, I'll buy you a new swing away!
PM or email me: trbenj@gmail.com
