  New Posts New Posts RSS Feed - Change from rack and pinion to rotary steering
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Topic: Change from rack and pinion to rotary steering
    Posted: September-04-2014 at 9:57am
Glad it works well for you sir.
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: September-03-2014 at 6:15pm
Thanks for the advice guys! I ordered the newer rack and pinion system from Zach at N3boatworks. I skied it hard for three days so far and I'm lovin' it! Smooth as silk!
...Time will tell if it lasts like the old rotary.
current boat
94 Sport Nautique
previous boat
78 Martinique
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2014 at 10:22am
Thanks Timmy, got him taken care of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2014 at 12:05am
Something must be wrong if your on your 4th in 20 years,just changed the one in my 95. Do you get alot or leave alot of water in the bilge? Do you still have the rubber boot thats mounted on the support tube or have you ever changed it? It's there to keep water from getting inside the cable. Teleflex SA37868P is the part number but hard to find,this place has them or whoever gets you the rest of the parts should be able to get you one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2014 at 9:06pm
Call Zach at N3Boatworks and he'll walk you through it.
Cc used a few different r&p systems the first few years after switching... The one that cc is currently using has been around for a while, is supposedly pretty decent, and very reasonably priced. It is the recommended replacement for those early r&p systems, as the whole thing costs about the same as one of those iffy old cables. Nothing wrong with rotary in my older boats but dads 03 and 09 steered much better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2014 at 8:59pm
TRBenj, I'm listening, but I'm not quite understanding your advice... What is "the latest R&P system"? And, where can I get one for $300? "Smoother steering than the rotary" sounds good to me.
current boat
94 Sport Nautique
previous boat
78 Martinique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2014 at 8:40pm
Forget the rotary, convert to the latest R&P system like paul did for $300 and call it a day. Smoother steering than the rotary for about the same cost as the cable (big-t helm is $$$). You should be able to keep your steering wheel as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2014 at 8:10pm
gun-driver, I knew someone would ask...
My LOVE of the Correct Craft brand started with my 1978 Martinique. The performance, handling and quality of the craft was like nothing I had ever experienced. The rotary steering on the '78 was one of my favorite features. Not only is it extremely easy to turn (at ANY speed, and in ANY kind of turn), and extremely durable, it is also extremely precise.
The rack and pinion steering on the '94 Sport has been quite a different story. I know I'm not alone in my disappointment with the steering on this model - I've read many other posts from other owners of the same model. From my experience with this boat (now in my 8th season of ownership); with enough effort and expense, the steering can be made tolerable, but it is very short-lived. If I want to have decent (tolerable) steering, I need to plan to replace the (VERY expensive) steering cable annually, and take the back seat, dog house, and floor panel out and re-grease the zerk fitting on the rudder semi-annually (or install an external zerk). Now, the helm itself appears to have worn out and needs to be replaced as well. So, I thought if I have to make such a large repair, I might as well go with the old tried-and-true system that I loved so much to begin with.
The current cable (at least the fourth one in this boat) has tightened-up so much now that it aggravates the arthritis in my elbow and the bursitis in my shoulder just to steer it sitting still! It has to go SOON!
If anyone can give me some advice on the subject of installing rotary steering in this otherwise AWESOME boat, I would really appreciate it.
current boat
94 Sport Nautique
previous boat
78 Martinique
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2014 at 7:31pm
My question is why??
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2014 at 12:41am
I would like to change the steering in my '94 Sport Nautique from the current tilt-column rack and pinion to a rotary steering system. Has anyone had any experience performing a swap like this? Is it possible? Can you recommend the correct parts for the job?
I tried searching the archives for a post on this subject and I didn't have any luck. So, if my questions have already been answered, I would appreciate help with finding the old posts.
Thanks in advance, jameski
current boat
94 Sport Nautique
previous boat
78 Martinique
