Trailer from 1967 SN |
FrankT
Senior Member Joined: September-07-2006 Status: Offline Points: 245 |
Posted: November-05-2014 at 9:20pm |
Trailer has ben sold.
Frank |
FrankT
Yes - trailer is still available.
Regards, Frank |
Just to clarify, this is a #3 trailer and is appropriate for 17-18' cc's like Cudas and Ski Nautiques. The frame dimensions didn't change much from the mid-late 60's through the 90's, surprisingly... So a newer/larger SN would technically fit on it... Though the load rating is likely 3500lb at best (later #3's got larger channel frames and beefier axles, etc).
While visually similar, a #3 from this period is quite a bit larger than a #2, which came under the 16' Mustangs, Skiers, etc. Loading a small boat on a #3 might be a chore as the wishbone frame is quite a bit wider (the track is about a foot wider). This trailer looks to be VERY well preserved with most of its original equipment intact. It's also priced very fairly- if it were close to me I'd be tempted to purchase it even if I didn't need it! These are hard to come by and set off a vintage boat perfectly. I hope a CCFan grabs it. Good luck with the sale, Frank. |
dochockey
Gold Member Joined: September-16-2009 Location: Colorado Status: Offline Points: 638 |
Is this still for sale?
1989 Teal Ski Nautique
1967 Mustang Harris Float Sunfish |
FrankT
Cincinnati is quite a bit to the north, approximately 500 miles north of Atlanta. For a CC guy $450 is fine. Would like to get it out of the way though.
Frank |
ScottZ
Platinum Member Joined: January-20-2004 Location: Clanton, AL Status: Offline Points: 1154 |
If you were closer to Alabama I would take it off your hands for $450.
Lake Mitchell , AL 1984 Ski Nautique 1972 Skier |
FrankT
Hopeful someone can use this before a local picks it up and converts to a lawn mower carrier. Any interest at $500?
Regards, Frank |
FrankT
Have a trailer from a 1967 SN. Needs a good wire brush and paint. Needs bunks and carpet. Has not been on the road since 1999. Tires appear to hold air but will need replacing. $600 or offer. Located in Cincinnati, OH 45215.
Frank (513)266 zero three eight two |
