  New Posts New Posts RSS Feed - Winterizing (beat this dead horse)
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Topic: Winterizing (beat this dead horse)
    Posted: November-13-2014 at 1:18pm
Spitting snow here too. Luckily we have the heat on at the shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2014 at 1:06pm
Seems fine outside to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2014 at 12:42pm
I didn't know air could freeze.
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2014 at 12:37pm
Son of a ......., lol, thanks Timmy, was envisioning that line allowing the water to exit instead of being within the block loop. Think my brain froze, been really cold here, actually had traces of snow on the ground this AM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2014 at 11:53am
Yes it would, but so what? Anywhere you plumb the heater, it's going to do the same thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2014 at 11:14am
Hah, knew you would chime in eventually Timmy, perhaps you could enlighten us dummy's, lol. Wouldn't that heater hose location allow water to flow from the block when cold which is what the T-Stat prevents??
As Tim mentioned Nate, most factory installed heaters are plumbed a bit different. Here is some pics of my SBC with factory installed heater.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2014 at 10:53am
Originally posted by N8higgies N8higgies wrote:
Quinner,
Thanks for the reply. I'm not smart enough to know if the heater is affecting the thermostat function...can anyone else weigh in?
Don't worry, Quinner isn't either. That's an acceptable place to plumb the feed, the thermostat won't care. You might get hotter water out of the intake though.
N8higgies View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote N8higgies Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2014 at 10:43am
Quinner,
I wish I would have thought of running the shower to drain the block. The impeller is my next step. But if I remove it, would I still be able to suck up the AF? That is why I was leaning toward just pouring it in somewhere...I just don't know where to add it. If someone could post a picture of which hose to pour it into, that would be awesome. Also, will pouring method fill up the lines in the heater and shower? Thanks again for the help.
Nate
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2014 at 3:12pm
Nate, interesting how the heater is plumbed one side directly to the block, seems like that would trump the TStats function??
Couple things I do slightly different:
Simply run the shower pump to drain the port side block and the shower CWS, be sure both H&C valves are open.
Remove impellor for inspection and add'l drain.
After complete drain I use the suck up method to add pink a/f via the intake line just past the strainer, takes about 5 gallons, run shower while sucking up until pink flows out, by the 5th gallon you should see pink coming out the exhaust. If no shower/heater less pink would be required.
Then fog each cylinder via the spark plug hole.
Nate's Video:
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2014 at 2:46pm
Try Florida Inboards in Panama City. Also a CCFan.
1974 Southwind 18
1975 Century Mark II
Post Options Post Options   Thanks (0) Thanks(0)   Quote N8higgies Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2014 at 2:16pm
Hello all,
I know this subject has been beat to death and believe me, I have read all the threads I could find about it. However, I want to make sure I didn't miss anything or, worse yet, do something wrong, so I made a video and put it on you tube so you experts could give me pointers/advice. The link is here:
http://youtu.be/Yir72hHdr94
Disclaimer: I don't consider myself much of a mechanic (or a videographer either) so please be patient. I just bought the boat a few months ago and want to make sure I take care of it properly. I live near Pensacola Florida in the panhandle, and there aren't any inboard dealers anywhere close that I can find, plus I'd like to know how to do it myself. The weather here doesn't get too terribly cold (only a few nights below freezing if any), but I'm military, so the next duty location could be quite different.
Thanks in advance for all the help.
Nate
