  New Posts New Posts RSS Feed - New ACME 1868 Prop for Sale
69 barracuda h/m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 69 barracuda h/m Quote  Post ReplyReply Direct Link To This Post Topic: New ACME 1868 Prop for Sale
    Posted: August-12-2018 at 12:52pm
Hey I have a 1969 correct craft barracuda with the Ford 302 h/m do y’all have any suggestions on a good prop to run other than original?
-Alex
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2018 at 8:53pm
I typically operate around 4,400 feet. Occasionally I run at 6,500 feet. My engine is the High Output 351 and runs around 290 ponies.
With the 654 operating at 4,400 feet, I get 4,800 to 4,900 RPMs and 43 mph. However, at 6,500 feet, 4,700 to 4,800 is all the RPM I can squeeze out.
Which engine does your 176 have? GT-40 engine?
The GT-40 would turn the 654 nicely. I would expect that W-O-T should be right where PCM says max RPM should be. When I had the 1868 on the boat for 2 ski sets, I had to keep an eye on the tach so as to not over-rev the engine a bit. Hole-shot was outstanding -- so if you want killer hole-shot, the 1868 is pretty nice. Just watch the tach...
Looking back, I should have kept the 1868 as my back-up prop. I don't typically run flat-out so over-revving wouldn't be all that big of a problem.
AlfaDon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfaDon Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2018 at 6:54am
Hi JQ,
I'm considering the 1868 or a 654 for my 98 176, when I need a prop for altitude (5000")
Why didn't the 1868 work for you? From what I've read the 1868 tops out pretty fast, but it seems like a better choice for altitude than the 654.
Thanks,
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2015 at 2:59am
SOLD
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2015 at 4:11am
Originally posted by halfnelly halfnelly wrote:
Still have it?
Still available. I've had some inquiries, but no ca$h yet.
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 4:19pm
Originally posted by Jonny Quest Jonny Quest wrote:
Absolutely perfect condition. Mounted the prop and ran for 5 minutes. Wrong for my application. Vendor won't take the prop back. :(
ACME 1868
12.50 X 14.250
0.075 cup
4-Blade
1" Shaft RH Rotation
Paid over $400
Make me a reasonable offer...
Sorry to hear that. One of the big reasons we sell and service OJ products. We will take a propeller back and get a customer into the right one,,,Usually the right one the first time.
1868 good for hopped up 2001 model SN's 82-89. Actually running one on our 09 6 liter.............comes out of the hole great! just kinda tops out quick!!! was a back up wheel.
halfnelly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote halfnelly Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 4:05pm
Still have it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2014 at 9:57pm
Sadly, I bought this prop before I found CCFan.com or skidim.com.
It annoys me that most lessons learned come with a co$t...
scootdogydog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scootdogydog Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2014 at 11:17am
Delta doesn't take returns if you use it...I called and asked them that over the summer as there were a few different props I was considering.
1999 Python
1980 Ski Tique
1968 Mustang WIP
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2014 at 9:15am
Rob,
I take it you didn't use Delta (site sponsor) since they do take returns (great price too). Who was it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2014 at 2:50am
Absolutely perfect condition. Mounted the prop and ran for 15 minutes. Wrong for my application. Vendor won't take the prop back. :(
ACME 1868
12.50 X 14.250
0.075 cup
4-Blade
Paid over $400
