  New Posts New Posts RSS Feed - Starting my trans rebuild tomorrow; ??
hollywoodswole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hollywoodswole Quote  Post ReplyReply Direct Link To This Post Topic: Starting my trans rebuild tomorrow; ??
    Posted: June-01-2006 at 7:28pm
Awesome. I wish you luck also, although you sound a lot more experienced. Putting it back in was not nearly as hard as getting it out. I managed to lift it in and get it bolted up by myself (unfortunately, I bolted the oil pump on backwards the first time - i thought my engine was left-hand rotation when it says right-hand on the tag). Y'all enjoy your weekend and I'll have some pics up soon that may help.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2006 at 7:03am
Cool; I'll be water testing my trans this weekend if the rain holds off. I added a remote oil filter to the cooler line; I concur, don't want to rebuild again for another 24 years.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote hollywoodswole Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2006 at 8:42pm
I'm really not sure how it broke, but when I took it all apart, it was the only broken piece. I did install a new forward clutch pack, as well as the rear clutch disk, even though they weren't broken. I don't ever wanna have to take this thing out again. I'm in the process of putting the pump back on, and it'll be back in tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2006 at 6:36am
yikes 25 bucks? its only 10 at ebasicpower.
How did it break? Did the pressure-plate saw through the tangs? Hope you are putting in new clutch disks, else it will happen again.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote hollywoodswole Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2006 at 4:55pm
The latest update:
I took a week off because of graduation and my birthday, and got back to it today. We got everything disassembled, and found the culprit. It was a broken clutch spring (#79 in the exploded view in the manual). All that for a part that costs $25. I'll start the reassembly on thurs, and hope to be testing it on friday. I'll keep y'all updated since I know there are people that may want to try this at home. Thanks for all the help so far.
Bob's2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob's2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2006 at 11:46pm
I got mine apart using compressed air. I have a blowgun with a rubber tip so it would seal pretty good against the hole. Gave it a couple of squirts and it popped out.
Bob Ed
83 2001
john33617 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john33617 Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2006 at 11:12am
http://www.amarket.com/imabw071.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2006 at 8:27pm
First needed to first tap the cylinder in a little to relieve pressure on the large snap ring before it would budge.
To remove the forward cyllinder from the ring rear I just supported the outer edge of the ring rear and used a block of wood on the inner snout of the cyllinder to tap it out. I had to get a little fresh with mine with a 1-pound hammer on the wood block. Once flush, I flipped it over and used the mass of the assembly and brought the block to bear agaist the concrete floor and it tapped itself out the rest of the way.
My piston was in good shape, just grabbed a non-critical area with some channel locks and rotated the piston , gently pulling and it slid out.
River Rat to Mole
Martinique87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Martinique87 Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2006 at 7:08pm
hollywoodswole,
I beleive that's your forward clutch cylinder. Are you tyring to get the piston out of the cylinder or remove the cylinder and piston?
If your removing the piston I assume you've plugged all of the place where air escapes when you use the compressor. As I mentioned before,mine was really stuck in there. Removing the piston was a two person operation, one to plug the holes, the other to use the compressor and tug on the piston.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hollywoodswole Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2006 at 1:18pm
GottaSki,
I don't have a pic of the part, but if you look at the exploded view in the manual, I believe it's #84 (pg 12 of the manual). It's also the pic found here in TexasBob's album. I can't get it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Martinique87 Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2006 at 9:59pm
I went into mine assuming I had a clutch problem but what I really had was a lot of junk in the forward cylinder and a corroded fowrad piston. Becasue of that my 125 psi compressor wouldnt do the job, I had to persuade it a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2006 at 8:15pm
Sounds to me like you are describing the reverse piston. I suspect you havn't found the forward clutch piston yet.
When together, a pressure guage on the rearward port would have indicated whether the piston seal went, or the forward disks went.
Stand on the piston so it don't hit you in the face...in only takes a little air.
perhaps I overspoke, are you talking of the holes in the case adapter or input shaft?
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote hollywoodswole Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2006 at 5:53pm
I hope none of these questions seem to elementary, but we can't figure this thing out. Our compressor can only go up to 100 psi. Is that enough to get out the forward clutch? And even then, how do you cover the other two holes so air doesnt escape?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hollywoodswole Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2006 at 4:42pm
Ok, so i've taken apart the tranny, and nothing appears broken or out of the ordinary. The last thing for me to check is the forward piston (I can't get it out til I have a compressor). Is there anything else that I need to look at?
To go back a few months, my symptoms were:
1. Reverse works fine
2. Forward will turn the prop, but only at idle, not under load. When you throttle, the shaft stays spinning at the same speed, while the engine just revs. ??? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote hollywoodswole Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2006 at 5:30pm
SUCCESS! Well, in getting it out of the boat. At least now I don't have to sit out in the sun while I work on it. More to come...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Martinique87 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2006 at 5:45pm
Okay, If I understand your question correctly you are trying to get the tranny removed. If so here's the deal
Remove the four bolts connecting the tranny to the shaft
Put a bottle jack on the stringer under an exhaust manifold, and have some 4X4's or something similar to put under the enginge later. Remove the bolts on the transmission mount so that it can be removed when ready (leave the "wings" on and they will be your handle to carry the thing out of the boat)
Next loosen the nuts on the engine mounts and give the vertical bolts a wack with a hammer....this allows the engine mounts to rotate.
Use the bottle jack to raise the rear of the engine enough so that the flange clears the driveshaft. Put the wood under the engine to keep it in place.
Unbolt the tranny from the belhousing. Note, half of them are nuts the other half are studs. The studs stay in place so you have something to line up with during the reinstall.
Grab onto the wings and pull the tranny away from the engine and be ready to lift about 100 pounds.
When you re-install you will have to do an engine alignment too...again,not so bad.
Hang in there, you'll get it.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote hollywoodswole Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2006 at 5:28pm
So I've run into my first "issue". I unbolted the prop shaft coupler, but still can't quite figure out how to loosen the prop shaft. I started turning on the big brass nut on the shaft, but the rubber sleeve was turning too much (I'm guessing the thrust washer is under there?). How do I move the prop shaft back far enough to slide out the tranny? Thanks guys. And happy cinco de mayo
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2006 at 9:12am
Tim is right-on
I was able to do mine without a puller or press, but ymmv
Don't put interferrence-fit parts together dry, else you only get one shot.
Quality snap-ring pliers and safety glasses are a must,
I put my ID parts in the freezer and heated the OD parts a little with propane then the bearings slid in nicely.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Martinique87 Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2006 at 10:52pm
hollywoodswole,
This is deffinitely do-able. I rebuilt mine with no prior experience and it works like a champ. Just follow the steps as outlined in the manual.
The only specialty toos I bought were a gear puller, snap-ring pliers and a torque wrench. I did have the gear pressed on in the shop since I don't have a hydraulic press.
One thing to look for is pitting and corrosion. If present use fine wet-or-dry sand paper to get rid of it. If the shaft is really nasty they make a thing called a speedy sleeve to cover it up.
Its easy to put the pump on backwards. Before taking it apart think about using a punch to put marks on the housing and the pump cover to ensure it goes back in the correct position.
One last thing, when your done and putting the cover in place be very careful not to damage the front seal with the splines on the shaft. I did just that the first time. Vince at skidim recommended covering the splines with clear packing tape, sliding the cover in place, then removing the tape. That keeps the sharp edges of the spline from damaging the seal. It worked well for me.
If you have any questions just keep posting, folks here are great.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote hollywoodswole Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2006 at 4:21pm
Looks like I got rained out today.
On a side note, after reading the manual from cover to cover, it says I need a bearing puller? Is this the same kind of thing I can go rent at the auto parts store?
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2006 at 9:49am
Another method is to support the engine with 2x4's under the exhaust manifolds supported on the stringers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hollywoodswole Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2006 at 5:44pm
Thanks. I was just out there and wedging a block of wood was the best I could come up with.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2006 at 4:41pm
just diconnect the mounts to the tranny and leave the ones to the motor alone and put a block of wood under the oil pan towards the bell housing to support it or just pull the whole thing, engine and tranny together. The block need to be wedged a little before you remove/loosen the tranny mounts otherwise it will sag and you'll have trouble going back together.
You could also support the engine from the topside with an engine hoist, come-along, chain or the like to a rafter, tree or anything strong enough over head to support the weight. If you don't have to move the trailer while your doing the tranny.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hollywoodswole Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2006 at 4:29pm
I've done some research into the forums and the manuals, and I think I know what to expect. My only question right now is how to support the engine while the trans is out?
Thanks for any help fellas. Now that this semester is over, I can't wait to get back to the lake.
By the way, I own the 81 Southwind in the For Sale section.
