propeler |
SS 201 ![]() Senior Member ![]() Joined: October-20-2003 Location: United States Status: Offline Points: 232 |
![]() ![]() ![]() ![]() ![]() Posted: May-06-2004 at 8:26am |
Eric Johnson at OJ propeller, 800 359 9730, he manufactures them. Buy direct, if you have problems he will live with you.
rick44 ![]() Newbie ![]() Joined: May-05-2004 Location: United States Status: Offline Points: 2 |
I have restored a 1974 matinique. I have had rebuilt the original 302 c.i.d. 4 barrel holly motor. I have increaded the compression, and beefed up the cam a bit. Maybe added another 50 h.p.from 220 to 275 h.p. By the way, the boat is 17' 9" and 2200lbs. The prop on the boat is a 12" diam. 15 pitch, right hand three blade bronze prop. { most likely original } This prop. is worn and needs replacement. Should I go with the same or can I get more performance out of a different diameter and pitch? I am inclined for more speed vs. "out of hole" performance. And, what about a four blade vs. the three blade? stainless vs. bronze? Finally, best place to purchase.
Rick |
rick
