Mustang Trailer For Sale |
Post Reply | Page 12> |
Author | ||
Stars06
Newbie Joined: November-01-2014 Location: Dyer Indiana Status: Offline Points: 10 |
Posted: March-20-2015 at 12:51am |
Sold
matthewbmiceli
Newbie Joined: October-23-2014 Location: Umatilla, FL Status: Offline Points: 21 |
Yes, they are, I was thinking the same in length and trailer size. Thank you for the guidance, I appreciate all the help I can get.
Morfoot
PM Sent!
The mustang 17 also used a #3 trailer, fwiw. Still a different hull than the Cuda, even though both were 17'.
matthewbmiceli
Thank you for the info. I'll do that.
Thanks for the explanation. Since it's the Cuda you need the trailer for, I'd suggest looking for a #3. |
matthewbmiceli
I have a 1975 Mustang, and a 1970 Barracuda. No trailer for the Barracuda. I can get a Shorelander, but was hoping for an original.
Matthew,
I'm confused. Cuda or Stang 17'?
matthewbmiceli
There are 16' & 17' Mustangs, I didn't think about the 16' as my Mustang is a 17'.
I concur. One year Charlie and I put his Cuda on my Tique trailer to get it into storage (he doesn't have a trailer) Even with moving the bow stop forward slightly, the Cuda wasn't very comfortable. |
The Cuda is not the same hull as the Mustang, it is almost a foot longer. Consensus seems to be that the #3 works better for it, but I've seen cudas with both #2's an #3's. It may or may not be too wide for a late #2 like this one, the earlier trailers had lower profile fenders and the boat did not sit between them.
matthewbmiceli
I have a 1970 Baracuda, same hull, if you still have the trailer I'll take it.
Stars06
This was the only pic I had of the old trailer
Gotta be a #2 as you thought.
Stars06
The width on it between the fenders is 60" the overall length of the trailer is 16' 9"
Frankenotter
Platinum Member Joined: August-26-2012 Location: Milwaukee Status: Offline Points: 1072 |
1999 Ski Nautique 196
A 176 will likely fit on an older #3. No way in heck will it fit on a #2, it's way too narrow and the boat sits between the fenders (the narrow mustang/skier/Tique only clears by a few inches). The latter also has a good chance of being completely overwhelmed by the weight, too. The earlier #2's had 2000 lb hardware (wheels/tires/hubs/axles) that was barely adequate for a 1600 lb 16' boat. The later #2's got upgraded spindles, hubs and wheels/tires (same stuff as a #3, so 3500 lb gear), not sure if the axle or frame would keep the weight rating lower... But I wouldn't chance it.
Either way, the older trailers weren't much, if any shorter in the tongue, so I don't think you're going to improve on the length if that's the limitation with your garage. Best bet is a modern trailer with a swing tongue. Does the 176 have removable platform brackets? Those 2 things combined with the short length of the boat should have it fitting in any garage... Though the width will probably require a 9' (wide) door no matter what. Grab some dimensions (width at the wheels and length from tongue to axle) and we should be able to confirm which trailer this is. I don't think it's original to the boat. |
Stars06
I'll measure the width tomorrow
Chevy350
Gold Member Joined: June-24-2013 Location: Illinois Status: Offline Points: 721 |
If you're talking to me no, but from the last time I seen my trailer which has a Mustang on it, there seems to be a good 4-5 inches. I could be wrong.... very wrong. But some modifications could be made for you to put i on just to sit in the garage . But, you'd have to ask someone who is smart unlike me for an exact number. |
1972 Mustang
Orlando76
I can't imagine it fitting. A swing away tongue isn't an option for you? Is your current trailer a RamLin?
Frankenotter
The beam of a mustang is listed as 5'10"
The 176 is listed at 7'4". Can you measure the width between fenders? |
Chevy350
My bad, I didn't mean wider. Old Ski nautique models and new are wider than the mustang
1972 Mustang
Chevy350
I don't know much about trailers but, I believe the mustang is wider than old and new ski nautiques. Could work but I'm not sure. |
1972 Mustang
Frankenotter
I'm interested in the trailer. I'm trying to fit my 176 in my 20ft garage.
Do you guys think this trailer would work for a 176. If so, I'm very very interested. Chris |
Stars06
Here's a pic of my boat, I've had it for 4 years.
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13516 |
you're not cool unless you have tape in place of a fastener somewhere on your trailer
Length and width. #3 channel grew an inch in height sometime in the mid-late 70's too. I posted a ms paint diagram comparing a few dimensions on the 2 vs 3 a few years ago, maybe a search would turn it up.
Mojo
Grand Poobah Joined: December-06-2006 Location: United States Status: Offline Points: 3106 |
Tim, whats the dimensional differences, both length and channel end width I presume ...? |
05' SV211 TE
C-Bass
Platinum Member Joined: November-18-2008 Location: Columbus, IN Status: Offline Points: 1248 |
Wouldn't take much to get that trailer looking nice.
Do I see duct tape holding the bunks on? |
Late 70's vintage with that bowstop... My '78 #2 still had the square tall version (no wood crash pads).
There aren't really any giveaway features that distinguish the #2's and #3's from that timeframe, they shared a number of parts (fenders, hubs, etc). Size is definitely different though, I'd recommend putting a tape measure on it to be sure. The 16' and 17-18' boats from th 60's and 70's would physically fit on eah others trailers but loading and weight distribution aren't ideal when swapped. Looks good though, and a nice price either way! |
