76 SN Rudder |
ScottZ
Platinum Member Joined: January-20-2004 Location: Clanton, AL Status: Offline Points: 1154 |
Posted: February-05-2015 at 10:53am |
I also have a 79 and 86 Ski Nautique as well.
Lake Mitchell , AL 1984 Ski Nautique 1972 Skier |
skutsch
Grand Poobah Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
Geez a Sport Nautique too, what year? I have a 98 Sport too - HA! Too Funny. I will keep you in mind. Definitely going to have to meet you some time. |
ScottZ
Let me know if another one come up that you are interested in. We have a tone of them here! I had to go up your way to get my Sport Nautique. The later models are hard to come by.
skutsch
****************** Threadjack Alert ******************
Scott Z !!!!! Where have you been, have had about 4 boats come up in AL, always looking for somebody down in that area to go look at them. How can there be so many used CC down in that neck of the woods and your the only one on this site - HA!!! Don't be a stranger... Wait a minute, your dad has my dad's twin Ski Nautique too ****************** End Threadjack ****************** |
ScottZ
ScottZ
I probably have a strut too.
ScottZ
I have a used 11A I will sell you.
I don't know of any available but in hopes of assisting in your search... You have 2 rudder options. 1)buy a new tabbed rudder... There are a few part numbers to choose from but you want the direct driver version with the 1-1/4" port. $$$. 2) the original rudder is a 11a, and came in most 18'+ direct drive cc's starting in 1970.
Tomahawk
Newbie Joined: October-15-2014 Location: Maple Grove, MN Status: Offline Points: 30 |
Thank you. Might be another thing to buy.
Eric, The ARE prop shaft is a double taper design. (taper for the prop and taper at the trans coupling) Many here including myself have used it. It greatly reduces R&R of the shaft. The original single taper shaft is a interference fit at the trans coupling that requires heat shrinking the coupling to the shaft. The ARE system cost is about the same you would pay for a single taper. Here's a link to the ARE explaning how it works. |
Tomahawk
What is ARE?
Wow! You do have a project ahead of you. Keep us informed and the pictures coming. If the prop was trashed, I'd say there's a good chance the shaft is too. Don't forget the strut ether. On the shaft, I suggest an ARE replacement.
Tomahawk
Prop was trashed. significant damage to port side from 6" to almost the wind shield. Need to figure out if drive shaft was damaged.
Eric,
Since the rudder shaft is in two pieces, then I'd have to say you do need a new or used rudder. I would not suggest a repair. What other damage was done to the boat? Pictures? |
Tomahawk
The rudder is broken in two at the base of the port. most likely part of the accident that damaged the boat. Port does not appear damaged.
Eric,
Whats wrong with your rudder and port? Repair is an option depending on whats wrong. |
Tomahawk
I need a rudder for a 76 Ski Nautique. I have both parts so repair is an option. Would like feedback on that.
