  New Posts New Posts RSS Feed - Depth finder transducer location
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Topic: Depth finder transducer location
    Posted: February-18-2015 at 11:18am
I put mine off center, tranny mount area. The transducer instructions said it could be up to 30 degrees off level. Supposedly you can use a bag of water to test your location for effectiveness, but I didn't get a consistent signal with that.
Use epoxy to glue it, not silicone seal.
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2015 at 8:44am
Mine is located under the driveshaft slightly aft of the coupler. Works like a champ.
'92 Correctcraft Ski Nautique
jhersey29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2015 at 12:10am
Whats the boat? My Super Sport has it right behind the belly mounted fuel tank but in front of the vdrive
1999 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2015 at 11:50pm
+1 on what Pete said!
Mine is located just aft of the drain plug under the oil pan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2015 at 11:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2015 at 10:12pm
Just aft of the pylon is the popular spot. Next to the rudder may be good sitting in the water but underway gets plenty of turbulence from the rudder and prop. I don't feel you will get accurate readings there.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2015 at 10:08pm
I would think towards rudder. I know on my G2 Ski the pylon area of the hull seems out of the water most of the time which would be useless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2015 at 9:58pm
My broken depth finder transducer was located beside the pylon. The new one recommends mounting by the rudder. Any advice on location and setup?
