  New Posts New Posts RSS Feed - 351w reverserotation gaskets
ArtCozier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Topic: 351w reverserotation gaskets
    Posted: March-16-2015 at 12:20pm
The change from 2-piece to 1-piece rear main seals on 351W occurred during the PCM 1984 model year. "Somewhere" I have the service bulleting that gave the PCM serial number when the change was put into effect, but "somewhere" remains a mystery.
When 2-piece RH seals became unreasonably expensive, we polished the knurling ("hash marks") off the cranks and used standard seals with no resulting oil leak problems.
"Art"
cueball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cueball Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 9:51am
Ordered the gaskets, and some other things...should be here by the end of the week.
Shawn
1986 SN 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote cueball Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 2:29am
Nevermind...I figured it out, two piece it is.
Once again, Thanks for all the replies!
Shawn
1986 SN 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote cueball Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 1:22am
Ok, after a little more research it seems my block is a 75-77. Cast #D4AE-AA
I guess the AA cast #'s makes a difference.
http://www.raceabilene.com/kelly/hotrod/engine2.html
So how do I tell visually if I need a 2 piece or 1 piece?
Yes, TRBenj, I agree, it doesn't sound right with the year gap with the hull year.
Shawn
1986 SN 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 11:45pm
A '86 boat with an original '74 block? That doesn't sound right.
Either way, if you have a 2-piece block and a RH crank with the wick lines, you should be good. Like TimD said, the seal is bidirectional.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 11:41pm
Go to NAPA and buy a $14 rear main seal. It will have the same Ford number stamped in it that the "marine" seal will have. Been there, done that 1998.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote cueball Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 11:27pm
The engine is original, to the best of my knowledge.
The crank is a RH and has the wicks on it, I checked the cast numbers.
I have a new cam for it and it is correct, I even checked it by setting it on top of the block and spun it in the direction it is supose to go and the lobes were correct.
Shawn
1986 SN 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote cueball Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 11:21pm
Thanks everyone for the replies,
Yes the numbers are Fel-pro, their website won't recognize the part number, but if you go thur the process to find gaskets for your engine, they come up.
Yea, I'm having a hard time finding the rear main seal.
I will try the link, Thanks Pete.
Shawn
1986 SN 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 11:13pm
The other day I was in the shop where I used to work, saw a couple of RH cranks there. They had light rust, but looked OK otherwise. Do you have the RH cam? They are getting very hard to find.
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 3:45pm
Roller block doesn't add any value unless you plan to go roller!
You're in trouble with a 2-piece block/crank if it's all LH... The RMS isn't an issue as it's bi-directional... The crank has the wick lines machined in and a LH crank can't be spun backwards. You'll need a 2-piece RH crank to use your 74 block. Or, get yourself a 1-piece block and crank to build from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 2:19pm
Looks as if he's using a '74 block,all the more reason to look for a roller block
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 10:18am
83+ should be a 1-piece directional seal, the 351 is sti available AFAIK, only the 302 had to be made custom (by Reid).
http://www.skidim.com/prodinfo.asp?number=MAL9-61626
Link
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 10:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 9:54am
Gary,
I went to Felpro without finding them. I must have had one of the jbear computer moments!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 9:52am
Felpro Pete. He might have problems finding the rear main though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 9:27am
Originally posted by cueball cueball wrote:
front timming #17795
rear main seal #17748
standard rotation, #17261,
Thanks,
Shawn
How about links? What manufacturer are these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 8:56am
Other than the seals,gaskets don't know which way the engine turns. Just use a quality set
Post Options Post Options   Thanks (0) Thanks(0)   Quote cueball Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2015 at 1:23am
Hi Everyone,
I am ready to order a gaskets for my 1986 SN 351w reverse rotation.
Block year is a 1974
Heads are a 1975
I know I need the front timming #17795
and the rear main seal #17748
So every kit I find is for standard rotation, #17261, will this work?
The only kits I find for reverse rotation is a rebuild kit, comes with bearings etc. which I dont need.
Any sugestions?
Thanks,
Shawn
Shawn
1986 SN 2001
