  New Posts New Posts RSS Feed - VDO Tach Dipswitch Settings w/Protec
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Topic: VDO Tach Dipswitch Settings w/Protec
    Posted: August-16-2016 at 10:49am
This turned out to be an issue with the signal from ProTech. Even with another gauge I had the same problem so I put this one back in.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
velde99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote velde99 Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2016 at 6:29pm
I recently bought a new old stock tach and it has the same setting yours has! So my original tach was the traditional 3 position (4/6/8) switch on the back. Worked killer- looked like crap. So I put this style in and it was crazy speratic and mostly never worked. I am not sure if it due to the pro-tech or what. Using my crappy one. I called a VDO dealer and he said the setting was correct. Not sure if the info helps.
Fl Inboards View Drop Down
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2015 at 1:47pm
Not sure I can be of much help as we only utilized that tach maybe 2 years have only been into it a few times way back in the day.
jimsport93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2015 at 10:33am
Joel, you may want to give Jody, at Florida Inboards, a call. He might be able to help you out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2015 at 11:15am
So I snagged a beat-up, used Faria Euro White tach on ebay as a replacement/test mule. Re-painted the bezel, then tried to install it. Friggin' thing doesn't have spade connectors- it has super long posts for all connections in the back and of course all the mounting hardware was missing as were all the brass nuts and washers for the posts. As i got into it there were so many things about it that were not compatible with the current installation, including bracket configuration, without some pretty major hacking. I made pigtails with ring terminals for all the post connectors, purchased nuts at Ace, and after screwing with it last night for an hour I threw in the towel and stepped back. Re-installed the VDO. Sometimes you just get too far down the rabbit hole without realizing it's just the wrong damn part.
My guess is there are multiple configurations for the Faria replacement gauges and I got one for a different application. Confirming that now.
In the mean time, anybody get a chance to look at their VDO dip switch settings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: March-22-2015 at 3:53pm
Joel, thought I would be able to fix you up. My dash is currently loose and the steering wheel is off. Pretty easy to check my tach.   Looked at the back of the VDO tach on my 93 Pro Tec Pro Boss. It has the typical 4, 6 and 8 cylinder selector and not the dip switch like you have. Sorry, I tried!
Nice boat BTW
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: March-22-2015 at 2:36pm
There is a hole in the Internet with regard to dip switch settings for an 8-switch 12V VDO tach. My tach on the 93 is WAY off, as in not even remotely close to the actual RPM. Lots of info on 3-switch setups. None on 8-switchers.
This particular tach has 8 dip switches on the back. I have no reason to assume that anyone has fooled with this as the dash looks like it's never been taken off of this boat. Still, I'd like to make sure these dip switch settings are right.
If someone w/Protec who has this gauge could just take a quick peek at the dip switch settings and snap a pic that would certainly help me out, and patch a big hole in the Internet at the same time.
