  New Posts New Posts RSS Feed - Advice needed removing ski pylon and engine cradle
85454Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 85454Nautique Quote  Post ReplyReply Direct Link To This Post Topic: Advice needed removing ski pylon and engine cradle
    Posted: March-24-2015 at 7:47pm
Thanks the hammer, pipe wrench and engine hoist method worked very well.
1985 Ski Nautique 454 Project Boat
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2015 at 6:00pm
Did you get under the engine frame at the base of the pylon before in goes into the glassed in socket with a big pipe wrench and give it a twist when you had it under load? Oh and is the engine still in the boat? if so under load rap it with a big dead blow hammer! Might have to get mean with it!
spiralhelix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2015 at 5:59pm
When my buddy removed the pylon from a '79, there was quite a bit of corrosion at the base. He used a big pipe wrench with a 3' long bar. Once he broke the corrosion, it came right out. He marred the base of the pylon a little, but polished it back up and looks brand new. Not sure if that is the correct way, but that is how he did it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 85454Nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2015 at 4:04pm
I am attempting to remove the ski pylon and engine cradle from my 85 ski nautique. I can't get the pylon to budge I tried lifting it with an engine hoist after removing all the bolts and all I did was lift the boat. What am I missing?
