  New Posts New Posts RSS Feed - Leaking at shaft
Leaking at shaft
The Lake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Lake Quote  Post ReplyReply Direct Link To This Post Topic: Leaking at shaft
    Posted: May-16-2006 at 7:54am
I would also suggest getting the teflon or or gortex or whatever that other stuff they sell instead of the wax impregnated rope.
Walk on Water
www.coldwater.me
69 Ski Nautique
AWhite70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2006 at 11:08pm
If your shaft packing has some room for adjustment then tighten the packing. It's the big brass nut with a locknut in your bilge where the shaft comes through. Loosen the locknut and tighten the packing nut until you get a drip of water about every 10 seconds. Then tighten the locknut and run the boat for awhile. Shut down engine and check to see that drip rate is acceptable and that stuffing box isn't getting too hot.
If your packing doesn't have any room for adjustment it will need to be replaced. Skidim.com is a good place to get the materials should you ened to go that route.
rlwiley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlwiley Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2006 at 10:15pm
1980 SN Major water coming in at the shaft. How do you fix this problem?
Thanks
