  New Posts New Posts RSS Feed - pimple blister gel work
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: pimple blister gel work
    Posted: April-15-2015 at 7:55pm
Brian,
From the picture, it looks like it's a candidate for a complete gel job.
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2015 at 2:41pm
Here is a pick of the blisters.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2015 at 9:52am
Thanks for the reply Pete, I grab some pics today. They are pretty bad, as far as they are everywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2015 at 7:30am
Brian,
You have the correct idea on blister repair. Depending on how bad the problem is, there are times where whole sections of gel is removed or even complete bottoms from the waterline down. Some hulls do it while others don't. Hulls that stay in the water seem to have more of a problem. The blistering is caused by water absorption and the reason base resons have changed over the years. If you are doing a few blisters and if they will be visible, the hardest part is the gel color match. How about posting some picturs?
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2015 at 1:02am
Does anyone have any guidance on where to begin on how to repair pimple blisters? I have a boat that is covered on the entire water line. I would think it needs to be sanded down so each blister is opened and then re-gel coated? any help appreciated.
