Transmission Slipping |
jpage
Newbie Joined: July-16-2014 Location: Atlanta,GA Status: Offline Points: 29 |
Posted: April-19-2015 at 11:34am |
'84 Mastercraft, with a new 351w, Ill check on the fluid today
jimsport93
Platinum Member Joined: February-20-2008 Location: Alpharetta Ga Status: Offline Points: 1750 |
John, definitely check the tranny fluid. I usually check it when first dropped in the water. Cold. Mine is a PCM 1:23.
What boat do you have? Motor? |
jpage
I did not check it, but did drain and add 1-½ quarts of fluid last week.
Toertel
Gold Member Joined: August-26-2013 Location: Atlanta Status: Offline Points: 775 |
Did you check trany fluid level?
If low clutch can slip |
1994 Sport Nautique
jpage
I just got my new motor in the boa as well as 14x18 prop. I took it out for a maiden voyage yesterday, Motor ran great, the transmission ( Power Slot)i believe started slipping around 4300 RPM's and boat speed was about 36mph. The motor jumped in RPM's to about 5k with no more forward momentum. Would this be the trans slipping? What is a good solution ?
