1988 SN 2001 Dash Switch/Fuse replacement |
spiralhelix
Senior Member Joined: August-06-2014 Location: IL/WI Status: Offline Points: 496 |
Posted: April-21-2015 at 12:31pm |
Nathan,
It looks like your breaker switches are similar to mine. They are a pretty straight forward switch with a "ring" nut holding the switch to the panel. You don't NEED to unscrew the panel, but it would help so you don't have to crawl under the dash. You should be able to remove that ring and the switch will then push into the dash. There are female disconnects on the backside that can be removed and then the switch is free to be replaced. I'm sure Zach at n3boatworks can help you get a new one. The ignition breaker is 20 amps i believe. Any chance that the switch just isn't screwed down tight enough? |
notnathan
Newbie Joined: April-20-2015 Location: san diego, ca Status: Offline Points: 2 |
My dash looks similar to
I can't get the ignition switch to stay depressed, and so I can't get the boat started. Does anyone know how to remove/replace? Do I have to unscrew the dash panel or can I access them from the outside? Its getting warm here, I need to get out on the water! Thanks |
