  New Posts New Posts RSS Feed - Just a little leak!
Just a little leak!
wataugasn84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wataugasn84 Quote  Post ReplyReply Direct Link To This Post Topic: Just a little leak!
    Posted: April-27-2015 at 7:20pm
Getting the boat ready last week while I was running the boat on the hose in driveway after 10 minutes I noticed a little drip at the front of engine .I first retightened all my hose clamps, leak still there. After a few more minutes drip was a small thin stream. I tracked it down to the top hole in the engine water pump. I am not a mechanic by no means ,water temp was good at 160 but I don't think water should be leaking from pump. There was a small area of rust from prior dripping of water I suppose. I ordered a new pump and belt set coming from Zach at N3boatworks. Is there anything I should know prior to installing new pump ? Common problems with installation ?
Watuugasn84
