transmisson problem |
floppy
Newbie Joined: February-01-2006 Location: United States Status: Offline Points: 31 |
Posted: May-18-2006 at 5:36pm |
thanks guys, I feel alot better now. I just redone the floor, carpet, ulpostry and had the carb rebuilt. Think i am ready to go and this happens. thanks again..........
Hey ya'll, Watch this!!!!!!!!
jimbo
It's pretty easy. I did mine a couple of weeks ago. The instructions are on p.24. There's a spring loaded ball behind the lever plate so be careful.
Order this gasket from Skidim: http://www.skidim.com/prodinfo.asp?number=RM0011 I matched up the o-ring at the auto parts store. |
GottaSki
O-ring. Its about as minor a job as you can get on that transmission. Check the manual as Rob suggests.
River Rat to Mole |
rmcdonald
Groupie Joined: December-30-2005 Location: Australia Status: Offline Points: 71 |
Hi Floppy
Check out the referece section of this site. You can download the workshop manual for borgwarner velvet drives. Regards Rob McDonald |
floppy
hey guys, I think i posted this topic in the wrong forum. Where the linkage goes into the transmission, There is a small leak. It seams like the only time it leaks is when the boat is in neutral and the shaft completly quits turning. Wondering if thier is a seal or O ring behind the stud that sticks out for linkage to mount on. Is this a major job? Thanks
