  New Posts New Posts RSS Feed - All courtesy lights out
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Topic: All courtesy lights out
    Posted: May-12-2015 at 10:04am
By courtesy lights do you mean the lights under the passenger seat and the gunwales? If bulbs check those, if OK then with a VOM or test light you need to see if you have power as Peter mentioned above
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2015 at 7:30pm
Tom,
Get the VOM out and start tracing the problem. Start at the source.
tlwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tlwolf Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2015 at 2:36pm
On my 2011 SN 200OB Team edition the courtesy lights will not come on. The blue indicator light on the push button switch comes on. The circuit breaker is not tripped. Have not tried it with the engine running. Nav lights are ok. Anyone with ideas? Thanks
Bay Rat
