  New Posts New Posts RSS Feed - Where is Faria gateway located?
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Topic: Where is Faria gateway located?
    Posted: May-18-2015 at 9:51am
In the trunk just below the lifting ring, if you have a trick tank it will be behind the little black plastic vertical cover.
okkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote okkman Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2015 at 8:38pm
My 2004 Air 206 started having some gauges drop offline occasionally last season. Just pulled it out and fired it up for the summer and NO gauges work at all. Reading through previous posts, it seems I need to locate and check the condition of the Faria gateway box. Before I tear every removable panel off my boat, can anyone tell me where it's located on a factory Air 206?
