  New Posts New Posts RSS Feed - Roar from transmission area after hitting rock bar
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Topic: Roar from transmission area after hitting rock bar
    Posted: May-20-2015 at 8:31pm
Originally posted by desertskier desertskier wrote:
Run it on the trailer in gear and watch the shaft spin. If it's bent you will probably see it .
NG,
Wow, you eye's must be better than mine. I have to use a dial indicator to detect the allowed .003" run out!!
Not just my eyes!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 7:40pm
Originally posted by Lostinattica Lostinattica wrote:
Thanks I was hoping I was right. Ok it's a 54" shaft. Is there anywhere or any links anyone knows of to properly install the packing or bushing??
I will post pix and a video from my pc this evening. I can't do it from my phone for some reason.
Again, check the FAQ thread.
Lostinattica View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 7:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 7:28pm
Ken,
Chance are high that the shaft is bad. Along with that and going to the ARE system, cutting is a logical and certainly easier way of removal. The alternate is to use the "long bolt and spacer" trick. The procedure is linked in the FAQ thread.
Don't forget the pictures!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 7:20pm
This shaft is wobbling by hand from the top end. I but I don't know if it's bc the packing is bad or if it's bent. I can't press this shaft housing off so I think I might cut the shaft and just replace the housing too. Thoughts???
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 7:17pm
NG,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 6:47pm
Why do you disconnect the rudder to remove the drive shaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 5:39pm
let's see some pictures of this mess
no fiberglass damage??
Mountain Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain Man Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 5:33pm
The shaft coupler can be disconnected at the transmission if that is what you are asking. There are two flanges that face each other at the tail end of the transmission (one stays on the transmission and one on the shaft) - there are 4 bolts set 90 degrees apart. Remove the bolts and the two flanges can be separated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 5:25pm
1 piece.
a: drop the rudder
b: press out of coupling (search how to do this)
c: extract from bottom of boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 5:21pm
It's an '86 model so I only have liability insurance on it. Obviously a bad decision. Does the shaft come apart or in two at the bushing under my back seat? Or will my shaft be one continuous shaft from prop to trans???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 5:20pm
It's an '8 model so I only have liability insurance on it. Obviously a bad decision. Does the shaft come apart or in two at the bushing under my back seat? Or will my shaft be one continuous shaft from prop to trans???
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 5:13pm
Run it on the trailer in gear and watch the shaft spin. If it's bent you will probably see it. Spray some water on the bushing to lubricate it. Don't ask how I know this. And as mentioned call your insurance if you need repairs. I got an ARE shaft, 4 blade prop, tunable rudder, steering cable, strut mount and bushing all for my $250 deductible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 5:02pm
Sounds like a good starting point. thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain Man Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 4:51pm
Sorry to hear about your accident with the rock. There are not many people that have operated boats for any length of time that have NOT hit a submerged object of some type. Couple of thoughts here - 1) do you have a dial indicator and know how to use it ? 2) do you have insurance - if so - this is a good time to file a claim and let a professional work on it.   Potentially bent shafts / struts need precise measuring tools to evaluate - probably can't eyeball it unless it's really bad. You might also disconnect the shaft coupler at the transmission, crank the engine and engage the transmission to see / hear if the transmission make the same noise - if yes you know the roar is in the transmission. If no, that's good news and you can focus on the shaft and strut.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 4:37pm
Yep, what he said. Drop the rudder. Pull out the shaft… have someone put it on a set of v-blocks and check the runout, or do a little research on here or elsewhere as to how to do that. Take a good hard look at the strut while the rest of it is apart. Its possible you damaged the transmission but the underwater gear is damaged far more often.   Damaging the transmission without bending the strut or the shaft would be unusual.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 4:24pm
Yes the rudder is bent some but I only had minimal tightness in the steering when I drove it back to the ramp.
So should I uncouple and pull the shaft out from the bottom?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 4:20pm
I can't see how you don't have a bent strut shaft and rudder. You need to take the shaft out and have it checked for straightness, then see if you can align it back from the strut through the log. The coupler must be tight too, if it comes out by hand you will need new.
Sorry, but you've got lots more problems than you seem to think...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lostinattica Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 4:17pm
Can anyone help me diagnose this issue? I was running about 20 MPH and hit a rock bar in the middle of the river (go ahead and laugh). My nav went from 80' to 5' instantly and the boat came to a complete stop. I replaced my prop and straightened my fins but there is still vibration and a roar coming from trans flange area. I can not see any damage to the shaft inside or under the boat or to the strut when I turn it by hand. Can someone help with steps for process of elimination? Even if I could afford a boat mechanic, they're ALL 4 to 5 weeks behind in my area.
