Steering 'release' coming off center |
tryathlete ![]() Platinum Member ![]() ![]() Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1799 |
![]() ![]() ![]() ![]() ![]() Posted: September-26-2015 at 2:13pm |
Ok finally got through the whole steering issue with the torque and release in the wheel at differing speeds. I repacked the rudder and all
Of the tightness and looseness is gone. The packing I took out was completely dry and there was no lubrication at all. The catch and release came completely from the rudder packing being probably original from 1996. Now there's nothing but the feeling of power steering! |
2008 MasterCraft 197TT
1996 Nautique Super Sport 1988 Waterlogged Supra Mariah |
Gary S found a loose carriage bolt holding the steering cable against the stringer. Gary just showed me a picture from a salvage parts NAUTIQUE that shows there is an aluminum plate affixed to the stringer for structural attachments. I'm going to drill and install a slightly larger fastener at boat storage time.
Thanks Quinner for lookin out for me! I'm going to replace my helm unit this Fall while doing other things. The PO had a frozen cable and I suspect he tried to use the boat with a very stiff cable for way too long and wore the teeth on the pinion shaft,or whatever that thingamajigy is in the picture. I have free play....measurable.
Maybe gary s can take a look with me this weekend. He's helped me along the path of making this boat purr.... Lots of little gremlins have been solved and now it's just all fun. Looks like I'll be a late comer on Saturday but all day Sunday....so stick round! |
M3Fan ![]() Grand Poobah ![]() ![]() Joined: October-22-2005 Location: United States Status: Offline Points: 3185 |
Sure enough, a small adjustment of the rudder tab and the symptoms are completely gone. Confirmed.
Gary,
The tilt mechanism locking was mentioned and the reason I asked about the mechanism that allows the tilt. Yup, that"universal" sure sounds like a engineers attempt at back yard hacking!! I wonder if Walters designed it? ![]() |
I'll try to find a picture Pete. It really is a cheesy set up,you for sure would think it was a back yard job. Kind of reminds me of that clevis you posted on the ski pole.
![]() This is the dash side Pete and below is the underside of the dash that mounts the rack to the steering. This is the part I had to change when I replaced my cable. The new cables use a wider rack,the original one will not bolt up to the newer style rack ![]() The allen headed bolts that bolt the two shafts together use nylon self locking nuts,cannot see how they could come loose but it might be worth checking out. Kind of hard to get inside to tighten up too. Wheel has to come off,hub and bellows too and very little room to work |
I've never had a tilt helm apart nor do I know what's inside. What is the means of the shaft connection at the tilt point?
At this point I'm convinced this has to do with rudder tab adjustment. It is not present at higher speeds so it's very speed-dependent. Generally right in the 25mph zone is when this odd behavior occurs. Pulling a 34mph skier in the course today the behavior was not present. It felt so mechanical when it was present but now I'm convinced it's not.
Basically it feels like it's a hydrodynamic "dead zone" in the rudder/water relationship. I've adjusted the tab a bit and I'm sure that's going to get rid of it. The entire steering system otherwise checks out. |
JayG80 ![]() Senior Member ![]() Joined: January-07-2007 Location: United States Status: Offline Points: 170 |
Reference to my post above about the allen screw. My 2002 Ski Nautique with tilt helm does not have this allen screw. I was getting a click/grab this a.m. going clockwise around ski course turn island. Took wheel off and only found a few phillips screws around housing perimeter. No center allen screw.
2007 Ski
2002 Ski |
@M3Fan
If you pull your decorative wheel cap off the center there is a single nut. Remove and remove steering wheel. Work off ribbed rubber boot that covers the tilt/helm mechanism...no need to remove dash components. Replace wheel without the nut so you can turn the shaft of the helm back and forth. If you turn it slowly while viewing the part of the shaft just deeper than the dash you should see at 180 degree intervals an allen head and a lock nut in a nut shaped recession. Tighten the allen head. |
2007 Ski
2002 Ski |
My 2002 Ski Nautique had the same troubling issue. I adjusted the trim tab on the rudder. I did not change the cable or make any adjustments to cause the problem but adjusting the rudder tab cured it. Just 2 screws.
If your rudder is older and not adjustable, I'd exhaust all other possibilities first and then try a small grind on the trailing edge of the rudder. I have also heard of a Allen head screw that is through the shaft of the steering wheel.. It may be loose and cause a interference - or worse. See linkDangerous Steering on 196 - Ball of Spray .com |
2007 Ski
2002 Ski |
KRoundy ![]() Platinum Member ![]() ![]() Joined: August-23-2010 Location: Lake Stevens Status: Offline Points: 1704 |
So, something is loose, right? Any updates?
I have the exact same problem. Just off dead center under power it binds then releases, Very annoying in the course and generally I find it at lower speeds like 25mph. My guess it is in the tilt mechanism, I went through the rudder/tiller/block/cable/rack and I can make it pretty clearly click from the helm.
Aengenend ![]() Newbie ![]() Joined: March-04-2013 Location: Netherlands Status: Offline Points: 25 |
I have the same issue, also after installing a new cable.
Did you find the cause? |
SN 93, Pro Boss HO, GT-40P, ACME 422
Keith ![]() Admin Group ![]() ![]() Owner / Operator of CorrectCraftFan.com Joined: October-20-2003 Location: Pepperell, MA Status: Offline Points: 1917 |
Yes, I did. All great suggestions, thank you. I should be able to look at it later tonight or tomorrow. Thanks, Keith |
I wonder if you had someone hold the wheel from turning and you would try to turn the rudder if you could feel any movement?
quinner ![]() Grand Poobah ![]() ![]() Joined: October-12-2005 Location: Unknown Status: Offline Points: 5828 |
Drove my neighbors new to him 96 Super Sport the other day and noticed a very similar condition with his steering. He just had a new cable installed and has a new prop as well. Be interested in what you find.
Keith - I bet you get this fixed for free at the next reunion!
Keith,
Go through your list of items that may cause slop in the steering. To me, it sounds like release is when it flips past the "top dead center" point, and the rudder shifts due to the slop in the system. Did you move the clamp tube in it's mount? |
I replaced my steering cable in my '97 Sport Nautique early last season. Since then, I notice a very slight steering resistance then 'release' when coming off center when under power (20 + mph.) and more pronounced at higher speeds (30 +mph). I notice it most when driving the oval at our lake, which is all left-hand turns - straight, hard left turn, back to straight, repeat.
In other words, once on center (i.e. steering straight) there develops some resistance and then a 'release' when turning from center. I assume this has to do with the position of the steering arm and the transition from 90 degrees (i.e. from pushing to pulling and visa versa). Again, only at higher speeds. Not noticeable when < 20 mph. I don't know if this is a problem with a) position of clamp holding steering cable near steering arm b) loose steering arm b) loose or warn rudder shaft (although no excess water in bilge) c) a function of prop wash d) some combination of the above e) something else entirely Thanks, Keith |
