PCM 40a Transmission Oil Pump Gears |
jbaisden
Newbie Joined: July-13-2013 Location: Indian Springs,Alabama Status: Offline Points: 14 |
Posted: June-10-2015 at 11:19pm |
Thanks guys, Mountain Man had what I needed. Fl Inboards: Out of curiosity what kind of price does a 80a transmission go for?
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2106 |
PM Art Cozier, he may have what you are looking for.
If you decide you want a new Series 80 Let me know I will get you the best price on line available.. |
jbaisden
I feel the same way as you Mountain Man. If I can just put a bandaid on this tranny so I can enjoy the summer some. I think I'm gonna start searching for a v-drive transmission for the winter project. I sent you a text with pics. Thanks.
Mountain Man
Senior Member Joined: May-09-2014 Location: Brevard, NC Status: Offline Points: 124 |
I have used PCM 40A 1.23: 1 that I saved for parts. Came to the conclusion after much research that I would prefer to put my money towards a new PCM 80A. If you would like to send me a photograph of the oil pump parts you need (you can send me a pm or text it to: 828-577-2553 whichever is easiest for you) and then I'll see what I can do to help you with the part.
A few things I learned while doing my research. This PCM transmission (or at least parts of it) were outsourced to ZF for manufacturing, so they may be a parts source as well. Also, PCM has a technician they recommend for repair / rebuild: Reggie Yarbrough (864) 909-2852. He may also have some parts. Good Luck! |
I'd give Fantastic Finish Marine a call however, you may be stuck with new since the gear problem sounds common.
I'm surprised you are attempting to source automotive parts. I have a feeling the PCM parts are OEM specific! When Eric owned FFM and was on site, he was always complaining about having to get PCM trans parts. |
jbaisden
1991 Sport Nautique
The idler gear on my oil pump on my 40a transmission shattered into 4 pieces subsequently causing my clutch packs to burn up and warp. I tried to buy a used one on e-bay only to see that it was cracked when it arrived. Does anybody know of a source for the gears? The only ones that I've ran across online are $270-300 or more. That's crazy money for gears considering automatic transmission oil pump gears are $30-50. from a trans. supply house. There's got to be another transmission or transfer case that has a similar pump gears. Most of the transfer case pics I've found the gears look very similar but with a measurement I can't cross reference it. I was hoping maybe somebody here has already figured this out or has a serviceable idler gear laying around that I could buy off you. With already having to replace clutch pack, seal kit, possible damper the $300 gear set is going to put me real close to just scrapping this trans. and looking to get something that i can find parts for. If I decide to get a different trans. what should I go with to replace the 1.23:1 that I have? I've always kind of wanted to covert it to a v-drive and I've seen some decent deals on some used one on e-bay. Does it matter what kind or type? I don't mind a little fab work but I already lost the last two summers due to a total stringer, floor replacement. So I would like to get back on the water as soon as I can get the funds up. |
