  New Posts New Posts RSS Feed - Scribing Main Stringers to the Hull
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Scribing Main Stringers to the Hull
    Posted: June-15-2015 at 11:23pm
Jon,
What are you using for stringer material?
Are we going to see some pictures? They may help us with advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2015 at 9:10pm
Jon,
I just googled "how to scribe" and there is plenty of info. Try taking a look and it may give you a better idea on the principle.
Beyond scribing when I really need extremely tight fit such as a wood spray rail to a wood hull, I will tape carbon paper to the hull. Rubbing the new rail on the paper shows all the high spots.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2015 at 7:05pm
Jon,
Level the top of the stringer. Find the largest gap to the hull. Scribe this dimension on both sides of the stringer. Plane to those lines and the stringer will fit. If you still have gaps or a "rocker".you aren't scribing properly.
85454Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 85454Nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2015 at 6:46pm
We have the boat level fore and aft. The stringers we pulled were so rotted they can serve no reference we do have a hand planer. If the stringer is touching in the back it won't touch in the front and vice versa we have tried bringing down the middle but it doesn't workout and we take a step back. Any other ideas? Maybe build the hull up?
1985 Ski Nautique 454 Project Boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2015 at 6:16pm
Jon,
They can be tricky but getting them to < 1/8" isn't too hard. Hopefully you have a power hand planer. Due to the angle. and it changing fore to aft, you need to scribe a line on both sides. Set the top of the stringer to a reference marks you hopefully have from the old stringers and scribe. You will probably have to do this several times. Level? Level with what? I always run a board across the gunnel and measure down to the top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 85454Nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2015 at 5:57pm
We are having a terrible time trying to get the main stringer to contact the hull and remain level. Any advice? How much gap is too much we are pretty much stuck.
