  New Posts New Posts RSS Feed - propeller
propeller
wesley64 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wesley64 Quote  Post ReplyReply Direct Link To This Post Topic: propeller
    Posted: July-02-2015 at 2:22pm
checked it again on phone gps.3800 rpm 41-42mph.wide open
i will see if secondaries are opening all the way
brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote wesley64 Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2015 at 10:55pm
i used gps on my phone but maybe the tach is not correct.
maybe i will check again tonight.
brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2015 at 9:47pm
Per PCM Owners Manual:
4,400 RPMs as a max intermittent cruise
3,600 RPMs as continuous cruise
In a properly set-up boat, you should be able to turn maximum RPMs with your propeller. If not, something is wrong, such as propeller diameter/pitch or engine problems. I'd double check the tachometer first. Take a GPS unit and see what the wide open throttle speed is per the GPS unit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2015 at 7:54pm
Originally posted by JPASS JPASS wrote:
Originally posted by wesley64 wesley64 wrote:
the max rpm is about 3600 roughly 45mph
brett
I don't think so... Better check your gauges.
+1
May RPM on my '92 is roughly 5000 RPM.
WOW!
Bret, is that what you are getting on the tach? If so, as mentioned, somethings wrong. Get a shop tach hooked up and find out.
The only 3600max engines I know of are old flat head 4's, 6's and 8's.
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2015 at 8:38am
brett
+1
'92 Correctcraft Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2015 at 8:19am
brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote wesley64 Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2015 at 2:11am
brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote wesley64 Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2015 at 2:09am
thanks,it is the 351 pcm that came with the pcm engine management system.
240hp?
brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2015 at 3:13am
OJ 14 X 16 3-blade was the standard prop back in the day. The new CNC props will be a noticeable improvement. I'm at high altitude (4,000+ feet) with the High Output 351W. I run an Acme 654 4-Blade 12.5 x 15 RH 1" Bore .105 Cup. At sea level, I run an Acme 422 4-Blade 12.5 x 15.5 RH 1" Bore .105 Cup
Which engine do you have? If it is a "PLD" engine (260 H.P.) then you may want to consider the Acme 654.
Do some searches in General Discussion and you will find many threads on props.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2015 at 12:14am
It may be the correct one but many have found improvement with the 4 blade acme.
I run a 224, I think many more prefer the 422. In my case the 4 blade Acme is quieter, smoother, faster and has more torque pulling load. I don't know an objection other than the $450 to buy one.
PS: I should note this is with the 310 HP 351 Pro Boss and it will RPM over 5,000 with this combo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wesley64 Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2015 at 5:37pm
hello all,i have a 1991 sn 351 pcm and 1.23-1 trans.my prop is a 3 blade 14rh16.
is this the correct prop?just wondering.
thanks
brett
