  New Posts New Posts RSS Feed - Interceptor exhaust manifolds
Cuda Chris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cuda Chris Quote  Post ReplyReply Direct Link To This Post Topic: Interceptor exhaust manifolds
    Posted: August-11-2015 at 1:07pm
1968 Barracuda Super Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cuda Chris Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2015 at 1:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2015 at 10:27pm
Cc used the rear exit outlets on the interceptors (not down angles).
The elbows were available in several angles. "down" was a bad term to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2015 at 9:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2015 at 7:43pm
Originally posted by Cuda Chris Cuda Chris wrote:
Will these work for you?
http://www.ebay.com/itm/1001523-1001524-Aluminum-Exhaust-Manifolds-Interceptor-Ford-165Hp-/400908271308?hash=item5d57febecc&vxp=mtr
How about these?
Same manifolds. The issue is the elbows. Correct down angles are needed and they might be harder to find than the manifolds!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cuda Chris Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2015 at 9:39pm
dochockey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dochockey Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2015 at 3:29pm
It says 1 available ? So I asked the seller but have not got a answer back ?
1989 Teal Ski Nautique
1967 Mustang
Harris Float
Sunfish
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cuda Chris Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2015 at 3:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dochockey Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2015 at 7:37pm
Hi
I'm looking for a set of original interceptor exhaust manifolds for a 1967 289
dochockey@aol.com
Thanks Kirk
1967 Mustang
Harris Float
Sunfish
