  New Posts New Posts RSS Feed - Teak Swim Deck
Teak Swim Deck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Topic: Teak Swim Deck
    Posted: September-18-2015 at 5:58pm
The teak care product I had been using is Meguiar's Gold Teak Oil on the swim deck. Based on OldSchool's recommendation, I bought a quart of the WATCO teak oil. The results I'm getting from WATCO are much better. Usually, I've had good luck with products from Meguiar's but their Gold Teak is off my shopping list. As a bonus, the WATCO is less expensive too...
91NaughtyQ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2015 at 12:53am
Originally posted by Jonny Quest Jonny Quest wrote:
How much pressure? Nozzle? I'm always careful with wood, as the pressure washer can do damage.
I used the WHITE end on my unit which is for washing cars. It removed the weathering, but did not rough up the wood in any way. Probably a bit under pressured, but like you don't want to damage it.
a0128 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote a0128 Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 11:41pm
Too much water pressure and you can end up raising the grain in the wood and having a mess on your hands.
If money can't buy happiness, explain beer and boats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 10:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 6:14pm
Originally posted by scottsims1 scottsims1 wrote:
Looks like new! East, right? Local guy wanted 100$ to do the same thing.
I would do every one I could find for $100 each. It was SO EASY. Just a few minutes of pressure washing and two coats of oil. Waiting the 30 min between coats took longer than anything.
scottsims1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scottsims1 Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 5:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 5:26pm
My platform after using the pressure washing / WATCO method described above. I wish I would have taken a before pic. It was grey at best. Thanks for the tip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scottsims1 Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2015 at 9:30pm
Watco is awesome and fairly cheap. I pressure spray my 06 then use a disposable paint brush with watco. Yearly job but best I have found.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2015 at 2:44am
Originally posted by IAughtNaut IAughtNaut wrote:
JQ, check this thread out. If you go down to the 2nd or 3rd post there are some great threads all about how to take care of your wood. Should have everything you need.
Don't know how I missed that thread on my "search". That made for some interesting reading. Ask 10 different people and get 12 different answers...
OldSchoolBlue84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolBlue84 Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2015 at 1:12am
I use to use starbrite which I had to keep reapplying. I went with WATCO® Teak Oil Finish and could not be any happier. Looks great on and off the water. I applied at the beginning of the season and did a very light coat before GL. You could pick it up at mostly any local hardware store for about $10.
IAughtNaut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IAughtNaut Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2015 at 11:55pm
bring the ruckus
2000 Pro Air
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2015 at 10:28pm
Pffft, Tell me about it...... I think light Olde English works just as good and costs less.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2015 at 10:18pm
My '94 S-N-O-B has a teak swim deck. The maintenance product I've been using is Meguiar's Gold Teak Oil to the deck. After applying the Gold Teak Oil, the swim deck looks great. Out on the water, the swim deck is a little slick for a few minutes with the Gold Teak Oil residue.
When I pull the boat out of the water and the swim deck dries, the teak looks like the Gold Teak Oil has never been applied. The deck goes from looking great to looking like an old, weathered, untreated deck. So, I find myself applying the Gold Teak oil after every trip to the lake.
Is this normal? If not, what am I doing wrong? Any other products that last longer?
