PCM model 40 1.23 trans |
KRoundy
Posted: July-21-2015 at 8:21pm |
And - please post photos of your 176!!!
KRoundy
Why do you think that PCM does not manufacture these?
There are pieces and parts available, but I am not certain I have seen the parts you are looking for. I'd call SkiDim and see what they might be able to do to help. There used to be a recommended rebuilder who frequented this site often named Eric who owned a shop called Fantastic Finish Marine. I believe the new owner / operator of Fantastic Finish has received good reviews here thus far. A good, reputable marine shop should be able to rebuild your transmission (I leave it up to you to discover who is good and reputable in your area). You can buy a new / updated version of the transmission from SkiDim. The PCM 80 A is a drop-in replacement for the 40 A for your year boat. |
bluelake
Newbie Joined: July-21-2015 Location: wisconsin Status: Offline Points: 4 |
Recently purchased a '96 Ski Nautique 176 with a broken oil pump impeller in the transmission. it would need an input shaft and the entire oil pump assembly to be replaced. Looking to source parts or buy a used/rebuilt/new transmission. it does not appear to me that PCM is the actual manufacturer of the transmission. Is there an interchange list of similar transmissions out there? Any leads would be appreciated! Joe
