  New Posts New Posts RSS Feed - Fuel Tank
Fuel Tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Tank
    Posted: August-11-2015 at 8:07pm
Originally posted by aw380 aw380 wrote:
Thank you. What if the screw is stainless?
It may be chrome plated brass as well. The late 60]s to early 70's was a transitional period. What's your concern if it's stainless?
aw380 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aw380 Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2015 at 10:55am
aw380
long123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote long123 Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2015 at 3:50am
A ground goes from that tab to the deck mounted filler pipe thru one of filler pipe mounting screws too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aw380 Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2015 at 11:25am
Thank you.
aw380
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2015 at 12:49am
well all grounds end up at the battery,normally you would bond to a buss bar somewhere usually under the dash. Your stern light needs to be grounded too. A ground goes from that tab to the deck mounted filler pipe thru one of filler pipe mounting screws too. Mine has a dash mounted gas gauge so there is a ground on the sender also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aw380 Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2015 at 11:45pm
I am restoring a 1970 16" Mustang. While assembly, I noticed a ground wire from a tab on the fuel tank.. Does it get grounded to the battery?
aw380
