unknown hose, fuel line? 1982, PCM, 351 |
ultrahots
Gold Member Joined: September-08-2004 Location: United States Status: Offline Points: 618 |
Thanks(1)
Posted: August-16-2015 at 4:28am |
Oil Drain Hose. Most I have seen have a Shower curtain clip on them holding it to the from motor pulling ring.
DMH
Senior Member Joined: July-25-2014 Location: Milwaukee Status: Offline Points: 134 |
Thanks.
Yes there is a plug in the end with a hole (see photo) and yes it leads to the bottom of the oil pan. I'll look for a clip |
ultrahots
Looks to be the Oil Drain Hose. Is there a plug in the end of it with hole in it ? If so, Follow it and I bet it goes to the oil pan. They factory had a little clip on it to hold it up top.
DMH
Hello,
Does anyone know what the hose or fuel line is in this photo. It just lays across the top of the motor. Your help is appreciated. Thank you. |
