87 SN Top Speed? |
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1797 |
Posted: September-25-2015 at 2:59pm |
HW---that was a rare epic fail moment. My only regret was not having my video on to capture it
2008 MasterCraft 197TT
1996 Nautique Super Sport 1988 Waterlogged Supra Mariah |
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
A fresh coat of wax helped my dads boat by almost 2mph.
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
kapla
wet feet Andy?
<a href="">1992 ski nautique
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
My stroker finally popped one of my airguides...they dont like being pegged.
This is the life
quinner
Duh Zach, don't know what all the debate is about, doesn't the speedometer go up to 50mph?? Learned long ago that's how you know how fast it is!!
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6150 |
12 at idle usually puts it at 31-32 all in on a stock dizzy. With premium fuel and 34-36 degrees you might find a little more speed but probably not an entire MPH.
When you set the things at the recommended 6-8 degrees you miss out on speed and acceleration. 26-28 degrees is just meh. I leave mine at 32 and run 87 octane. Mine consistently gets into the mid 45 mph range and has ran as high as 46.2 in perfect water/air conditions. (85 long nose = faster by 2 mph or so). |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
As Zach said, 45 is great for a 87-88. What GPS were you using? A true Garmin or a reliable app (like Navionics) is recommended. I've played with a few 87-88's and have ended up in the 43-44mph range pulling every lever I have.
AAM196
Gold Member Joined: October-23-2012 Location: Pittsburgh, PA Status: Offline Points: 846 |
45 is very respectable!
Morfoot
Old Post from Dec 2010...... I believe the timing is at 10' BTC. haven't GPS'd top speeds on Miss Scarlett lately but I'm thinking 45mph???
WOW! Holy cow what a difference the 540 made on the boat. It's just as everyone has described here as the hole shot was incredible. The bow came up about half as much as it did with the Federal 13x13 and it was allot smoother. The boat seemed to handle more solidly and with just me and a 100lbs of weight on the observer side to balance it out she seemed to turn more solidly with less cavitation of the prop in high speed quick turns. I did (as expected) lose a little top end but it's rare that I throw the hammer down and run full throttle so that doesn't bother me. I did forget my notepad in the truck but took some snaps with my phone and recorded a few readings. It was money well spent and I too am looking forward to the first chance I have to ski and wakeboard behind her. Merry Christmas to me! This is on a stock 351 with pointless ignition with 890 hrs on her using a GPS for velocity. Weather conditons weren't ideal with a little breeze blowing. 2200 - 22.2mph 2400 - 25.4mph 2650 - 28.3mph 3200 - 34.8mph 3550 - 38.1mph 3800 - 40.3mph 4600 - 43.5mph |
SWANY
Senior Member Joined: August-12-2014 Location: batavia Status: Offline Points: 384 |
[QUOTE=Hollywood] Sure felt like 45 mph on that first trick ski raft slider at quinner's...[/QUOTE
Oops. I set timing at 12 at 650rpm if I remember right. Advance was working good at 31. Was a couple months ago I checked it again but I think those were the numbers] |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13513 |
phatsat67
Still, 45 MPH out of an 87- hull is very good.
Have you checked all in timing Joel? There may be a little more power left on the table there. |
SWANY
GPS 45 mph.... Air guides were adjusted to high. Little disappointed. All the more reason to do some engine upgrades
gas_it
Newbie Joined: August-23-2015 Location: Athens, AL Status: Offline Points: 5 |
Thanks TRBenj, SWANY, MrMcD! I will look in to this prop you are speaking of. My past experience like I said has been 42-43.
MrMcD, if you're footing at 37, you & I weigh virtually the same, tells me I should be able to still foot at 39. According to rule of thumb calculations that I read, speed is = (weight/10)+20. That pretty much puts me at 39 or so. Your footing at 37 just reinforces that theory. It's been about 25 years for me. Maybe I'm trying to stand up too quickly and not letting the boat come to full speed. I'm going to give it another shot this weekend and stay on the kneeboard as long as I possibly can. If not, we'll re-prop! Thank you once again guys! As stated before, I'm not worthy of your knowledge. |
Hollywood
Judging by the first raft start at quinner's over the weekend I can say Joel's boat is running very well!
SWANY
I'll keep my fingers crossed till I get out again to confirm
I suspect Joel has a freakishly fast boat on his hands or his GPS verification will be eye opening... I've never seen a stock 2001 (save for the 454 boats), let alone a late one run anywhere near that fast. Some of the healthier early (82-86) hulls can top 46, but even on those it seems 44-45 is more typical. The late boats (87-88) gained a little weight and pushed it forward with the deck change- so they're a little slower. Anything over 43 unloaded is going very well.
For that reason, the 540 is what I usually recommend for an early boat, and the extra 150-200rpm the 542 will spin is what I'd try first on a later boat. 4400-4600 is the wot rpm to shoot for to optimize all around performance. |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3734 |
I think you have received great advice already on prop issues.
I barefoot at 40 + at 28 years old but now at 57 I am just fine barefooting at 37, the boat will go nearly 45 with a footer but I don't want to. If I foot now it is just for fun. I am just fine following the boat and avoiding face plants. I come up deep water and it does make a lot more spray at the slower speed and I can't slide around side to side but heck it is still barefooting, 37 or 41 isn't it and I am 20 pounds heavier too. 175 became 195 unfortunately with less muscle tone for sure. |
SWANY
I can get 48-49 out of mine with A fresh acme 540. I meant to confirm that with gps this weekend but forgot the gps in the truck. Granted I've gone through the motor and replaced most maintained items (points,plugs, cap,wires,coil,ballast resistor, all new hoses, carb rebuild. Fuel system. I'm a firm believer having gone through all this now that getting the driveline all dialed in makes the biggest difference. No resistance on the motor and trans is going to equal better speed. Engine alignment, cut less bearing,strut alignment and shaft packing. If your prop isn't spinning freely with one finger fix it. Definitely rewarding when you get to that point.
Someday I'll try the 542 per tim's suggestion. |
42-43 is about right for that hull and engine. 39 is definitely under performing. I assume that is unloaded rather than with a footer in tow? I'd expect to hit 40, maybe 41 with a footer.
I'd start by going through the ignition to verify a good state of tune... Then I would invest in a modern prop. Acme 542 on that hull. |
gas_it
First of all, many thanks to the wealth of information that I've gained from CCF over the last 2 1/2 years. I'm not worthy of your knowledge.
I have an 87 SN 2001, standard issue 351 PCM, just bought and got back in to skiing after 25 or so years. Yes, I'm an old man now. I used to love to barefoot back in my younger days, so I thought I'd give it a whirl again this summer. Yeah yeah, I know, I'm carrying an extra 20 pounds or so, but, I used to BF no problem at 39-40. My 87 SN is all out at about 39 mph and it's just not quite fast enough to get my fat butt going on the feet (I'm about 190# now). I'm curious to know if that speed is average? I used to ski behind a 76 SN & it would run about 43 or so. Can I re-prop and get another 3-4 mph out or her? I'm pretty prop ignorant and don't even know what's on the boat. I'm assuming there are probably some markings on it but I haven't gotten down there to look. |
