Bad compression test on 1995 Sport Nautique |
Author | ||
Blamey
Gold Member Joined: August-18-2015 Location: White Plains,NY Status: Offline Points: 631 |
Posted: August-26-2015 at 5:58pm |
Nope, this is spot on. I really know very little. I did own a '82 ski supreme about 10 years ago, the boat was a real POS, terrible condition, engine had major issues. It barley ran but I loved that boat. I didn't own it long enough to get to know it or have the money to get it fixed up. Sold it when I moved to Europe. I've wanted a Nautique ever since.
This is what I was hoping you'd say. I could probably stretch my budget to get a nicer boat but I really wanted to get something I can learn on and get fixed up before spending more. I am going to test the boat this weekend. If it looks and runs like I've been told I'll buy it. |
backfoot100
I get the impression that you're relatively new or "less than experienced" when it comes to boats. Not meaning any disrespect, mind you and if I'm wrong I certainly apologize.
With that in mind I concur with what Joe said. Those compression numbers are not horrible and I personally feel you could get several good years out it with those numbers before you have to worry about. The mechanic says it runs strong and based purely on those numbers, I would probably whole heartedly believe him. My stock engine had numbers very similar to that for 6 years before I did anything with it and it still ran pretty strong. We put over 100 hours a year on it like that. Buy it and use it and get a feel for the old girl. Get some experience on operating and maintaining it with the help of this forum and go skiing for Christ's sake. Have some fun. |
Eddie |
Blamey
The boat reads 402 hours on it but the hour meter stopped working. Owner estimates it to be in the low 500's.
Blamey
Thanks, this has been very helpful. I spoke to the mechanic that did the test and here is the info.
- The boat was last run 2 weeks ago for a test drive and that the only time it's been in the water this year. It did get new battery at the time. - Mechanic says the boat runs great. No noticeable issues when they did the test drive. - Engine is a Pro Boss GT-40. - Compression test was run cold, going to get it run again when I go for my test drive. - I may have miss spoken on the 'new heads' recommendation, speaking to the mechanic in detail they recommend 'inspecting the heads and replacing the values'. From what I have read, if the engine is running well then we could be good here and since it hasn't really been on the water this year getting it on the water a few time may clear up the issue. A hot compression test will also give me a more accurate reading, and if that comes out better we should be okay. If the compression is bad on the hot test, would I still be able to run the boat until the issue becomes noticeable without causing additional damage? Or is this something I should get fixed ASAP. |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3736 |
Also you should know how many hours are on this boat. Hours make a difference. Even very well maintained many parts wear with hours used.
If your comfortable with it and know the costs you'll be fine. A leakdown would be best,but you could maybe use that compression test to help in the negotiations. A leakdown test would indicate to you better what is exactly wrong but is not easily done unless you have the tool and a compressor.
JPASS
+1 I'd check the compression again. We had ours checked yesterday when we traded her in and she had 150-155 on all 8 with 1820 hours on her. Why are they recommending new heads? Did they do a leak down test or anything? |
'92 Correctcraft Ski Nautique
JoeinNY
Its too hard to see from over here how meaningful that compression test is. Relative numbers on a gage mean something, ie the 25% difference on the two cylinders but the absolute numbers have a lot that go in them. I have engines where 130 on a gage is a new and happy engine, and others that run 210 plus. If the gage was solid and the battery was strong and you are checking an HO engine then they are low, but not hugely low. If they are significantly low you would need to do a leak down test to determine if you have a problem with the heads, rings, or both. Assuming it is related to the heads simply from the compression test is a stretch. If it was the heads and you spent a grand on two newly rebuilt gt40p heads you would likely end up with a very new feeling and strong engine that you would expect to stay that way many many years. If it leaks through the rings then changing the heads would be useless. All that being said I would run that engine with good oil, good gas, and some fuel system cleaner maybe the occasional snake oil treatment for a season and see if you didn’t run the rough right out of it.
Blamey
Thanks,
Trailer and interior I am comfortable with. I have done my research and know the costs. I'll try hard to get a used trailer over the winter, if I can't I know I need 3.5k to 4k for a new one. Interior, I need to see the boat to make a call, if the interior looks terrible I'll walk but if it's something I can live for for a season or two I am happy to get the boat and then get this done in 2 or 3 years. My question is mostly around the engine what the compression test means for the remaining life of the engine. Will new heads fix the issue or could it still be a problem afterwards? Is a full rebuild something I should consider? Hollywood, I'll definitely ask about this. I plan to go see the boat this weekend test drive it and we can get the compression done over the weekend. |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13513 |
looks like it was done cold. engine may be OK, test again warm
The others will chime in but I would think that's high with no trailer and questionable interior. Figure at least 3k for a complete interior to original specs. Heads almost half of what they quoted if done yourself. Trailer can be 3-5k if new.
Blamey
$7,500 without a trailer, interior looks good in pictures but I haven't seen it in person yet. I plan to see the boat this weekend (its a 4 hour drive but close to my in-laws). Owner already offered to knock $500 off after the test.
Personally I like the idea of getting it down to $6,500 and getting the engine done. Total cost of $8,500 with new heads seems good to me, but like I said, I am no expert. Which is why I am here. |
How much they asking and what is the interior like?
Blamey
So I am looking at a 1995 Sport Nautique. I had the marina it's at do a compression test on the engine with the following results.
1 120 2 100 3 120 4 110 5 120 6 110 7 90 8 120 So I am new to this but I know this is bad, Overall the compression is low and 2 and 7 are very bad. Can you guys help me with my options. Should I still look boat if I can negotiate a discount. I plan to buy the boat now but won't really use it till next winter. What would I do to fix this. Marina has suggested I replace the heads for an estimated cost of $1,500, which I would negotiate the owner covering some of cost of the rebuild. What is the likely result after the new heads are put, in. Does it mean I have brand spanking new engine that will last another 1000 hours. Would it be better to just do a full rebuild or repower)? I am buying this boat partly to use but also because I want to have something to work on mechanically. I want to learn about the engine and parts, Get the boat fixed up and looking great. Basically something to keep me busy both in and out of the water, Lastly, is fixing this something a novice could tackle with lots of time to learn and get it done, or is this best left to the professionals. |
