  New Posts New Posts RSS Feed - A rudder lubrication/packing question
geecee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geecee Quote  Post ReplyReply Direct Link To This Post Topic: A rudder lubrication/packing question
    Posted: September-07-2015 at 8:05am
great thanks, ill take the risk and order some
I read the same sizes elsewhere so its a pretty good chance of being right :D
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: September-06-2015 at 9:58pm
I believe the rudder is 1/4 and the shaft is 3/16. You will need about 9"., West Marine.com has it online. I agree on the hard steering possibly being the cable. Disconnect the rudder and see if it turns easily, if it does you need to replace the cable. . Also some people actually have grease fittings on the rudder nut.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2015 at 10:26am
Not sure, but you can use a drill bit as a gage between shaft & gland to check    it will either be 3/16 or 1/4 inch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote geecee Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2015 at 4:25am
Thanks for the input guys, ill do some googling and see what I can find.
Any one have an idea of the correct packing for an SN2001 ('83 model), I'll have a look in the manual in the meantime hopefully it has the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2015 at 9:36pm
Originally posted by geecee geecee wrote:
I have been struggling to find packing this side of the world, ,
Graeme,
Where have you been looking? Gore is a world wide company so see if you can find an industrial distributor that handles their GFO packing. Over here, I get 50' rolls from McMaster Carr. They have smaller lengths too plus, lots cheaper than the "marine" supplies or marinas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2015 at 11:09am
If it isn't leaking, then the packing can be reused.   A light coating of grease (on the entire shaft) will help with friction, but it doesn't last very long.    Use a waterproof grease.
I did same thing, BTW.
If you have stiff steering, could be the cable too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote geecee Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2015 at 8:27am
Hello again, as I am still very green when it comes to working on inboard boats,
I have a question regarding the rudder.
I want to re-grease the rudder, as I don;t think it has had much love lately. Will I need to get more rudder packing or can I reuse what is there should be be "okay"
I have been struggling to find packing this side of the world, but with a stiff steering I thought I should check the rubber lubrication.in the meantime. I have finally gotten the clearances so I was planning to head out for my maydon voyage on my Nautique this weekend.
I am sorry if this is covered somewhere but I tried numerous searches to find more info on this, but came up short,
