  New Posts New Posts RSS Feed - Velvet Drive Rebuild (Ikr?)
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Topic: Velvet Drive Rebuild (Ikr?)
    Posted: September-10-2015 at 2:53pm
mikestoner93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikestoner93 Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2015 at 1:56pm
google found me this: http://www.mastercraft.com/teamtalk/showthread.php?t=53874&page=6
I tried to be awkward once... Just to see what it felt like...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2015 at 10:21pm
Originally posted by Dreaming Dreaming wrote:
Mike - there was a thread linked here that is to the mastercraft team talk site.   there are pictures of a teardown and rebuild in the thread.
Kris,
That was NOT a teardown and rebuild!! All that MC owner did was a clutch pack and seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikestoner93 Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2015 at 6:23pm
Sweet, Thanks ill check them out.
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2015 at 5:41pm
Mike - there was a thread linked here that is to the mastercraft team talk site.   there are pictures of a teardown and rebuild in the thread.   you might do a search for that on either site.   Joe in NY has done a couple of these as well.   might be worth dropping him a PM if you run into any trouble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikestoner93 Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2015 at 3:47pm
Dirty Idle, bit of junk the size of quarters floating around, chocolate milk flavored trans fluid, probably 20+ years since last service and probably 100+ hours run under conditions above, I think its a little overdue.
So tried to flush it but the junk wouldn't stop showing up so just decided to pull. Also found leaking Rear Main Seal :P
Going to clean and inspect the trans to see what needs to be replaced/serviced.
Its is an as1-70c has 1:1 ratio, anyone have and tips or tricks i should know before cracking this thing open?
