Accelerator pump diaphragm |
Bri892001
Posted: September-29-2015 at 10:10pm |
I have the green one that skidim sells:
http://www.skidim.com/Holley-Parts/products/1055/ They say it's compatible with alcohol based fuels. I was just in there this past weekend. I had to swap out the fuel bowl, because one of the accelerator pump-diaghram-cover-screw-holes [that's a mouthful ) in the bowl was stripped out. I wound up putting the green skidim acc pump diaphragm back. It was still in great shape after 3 summers. |
I wonder if the marine kits come with "alcohol" diaphragm because that's what came in my kit
Gary,
I've never rebuilt the carb and don't know if a PO ever has. The engine runs great but since I pulled the carb, I might as well do a rebuild on it over winter. Summit has two diaphragms available. The regular black one and a blue/green that's listed as "alcohol" hence the question. I'm assuming they mean it's good for ethanol. I'll know more about the condition of other internal rubber parts once I open it up. |
Not me I'm keeping mine original. Actually the last one I installed is a light green diaphragm maybe since you did yours Holley changed them?
When winterizing my 302 today, I found a fuel leak. I pulled the carb and found the accelerator pump diaphragm in real bad shape. Has anyone gone to the alcohol diaphragm instead of the standard black rubber one?
