DIY Sanford and Son Boat Lift |
Page 12> |
Author | |||
majestic ![]() Newbie ![]() Joined: March-22-2021 Location: USA Status: Offline Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: April-14-2021 at 8:24am |
Hello
Any luck for us? Did you find the originals? Regards
Watauga ![]() Senior Member ![]() ![]() Joined: June-12-2009 Location: United States Status: Offline Points: 208 |
Friends, Sorry I haven't been able to reply to this thread. I am a disaster responder and have been pretty busy with the tornado response in Alabama and the ice freeze in Texas and Oklahoma. This weekend I will take a look in in picture files and see if I can find the originals.
beretta5spd ![]() Senior Member ![]() ![]() Joined: February-16-2013 Location: Gladstone, MB Status: Offline Points: 255 |
I did a google image search for "home made boat lift" and after doing a bunch of scrolling it came up on pinterest of all things referencing the original post in this thread.... I knew I had seen it somewhere!
1996,1997 Sport Nautique 1986,1992 Ski Nautique - Sold
1995 Sport Nautique - Current |
Dwight, Were did you find that picture? Looks like the lift was in the Chicago river on St. Patrick's day!
I was able to do some searching for you in the background.... and tracked this photo down. It's the only one I could find of this setup. I hope it helps!!! ![]() |
Colinnap ![]() Newbie ![]() Joined: April-05-2021 Location: Canada Status: Offline Points: 1 |
Hi there! I’m sorry if this is a burden but I am very interested in recreating your lift! I cannot see any of your pictures for some reason. Forgive me if I’m doing something wrong..
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11184 |
Unless Watauga posts them again, they're gone with the wind, due to a slight site problem in July 2020 that made lots of stuff disappear.
Hello Thank you for this post, where can I get the pictures please? I can’t see them on the posts. Best regards Majestic
muddnsnow ![]() Newbie ![]() Joined: September-29-2020 Location: Appleton, WI Status: Offline Points: 1 |
I'm extremely interested in your design.. unfortunately i do not see any pictures, they are not showing up. Any help you could give will be greatly appreciated!
Joe
I think you're missing a factor with the lift floats. That is, you are not pressurizing the float but rather adding the pressure just to displace the water. So, the pressure in the float should be close to equal of the water pressure. |
shierh ![]() Gold Member ![]() Joined: April-29-2015 Location: Florida Status: Offline Points: 605 |
Yes , However I was merely discussing increasing pressure and the ability of the plug to say in place. |
Yes, the deeper you go, the more pressure is needed inside but, that doesn't increase the lift. Think of a sub submerged just below the surface and then 100 feet below the surface. It's buoyancy is the same at both depths. |
I meant completely submerge a container that was full of air. deeper you go the smaller the container would get and an increase in pressure.
Duane in Indy ![]() Platinum Member ![]() ![]() Joined: October-26-2015 Location: Indiana Status: Offline Points: 1578 |
Comes from too many years of working on Nitro cars and smelling the fumes ![]() |
1978 Mustang (modified) |
Duane, you're just so predictable, I had a really good idea what I'd see when I clicked on your link ![]() |
To increase lift, the volume of the container(s) must be increased. Lift is determined by the displacement of the weight of the water. A cubic foot of water is about 62.5 lbs. There are about 7.5 gallons in a cubic foot. |
guess only way to increase the pressure is to completely submerge thereby reducing the actual size of the container,
Case in point Pete tire deformation |
The tires on your car deform some but they still hold the car up! ![]() |
does it make a difference if the container is not that rigid and may deform some?
I asked Google cause the first number seemed awful small
As an estimation, I use 44 pounds per 100 ft (or .44 pounds per foot) as a thumb rule from back in my Navy days. That thumb rule was for saltwater but it gets you close |
jstainer ![]() Newbie ![]() Joined: March-14-2018 Location: Ocean City, NJ Status: Offline Points: 4 |
Much appreciated! Cant wait to get started! I will definitely look further into the materials to use.. I heard great things about the unistrut! Saw tests of it holding up to over 2000 lbs of force bouncung and pulling on one spot.. so when all bolted together and working in unison.. its pretty strong stuff.. they also make a double width section.. loiks like a 2x6 box steel tube. Was planning on using that for main beams.. some of the hydro hoist models seem to use very thin materials... no clue how they hold up so well...
Well Ken, I actually used one of the online converters originally then, I was having breakfast and started thinking. I've always used 27" as a base line for 1 PSI so realized the original answer was wrong. Thanks for noticing the correction. |
Nice edit job on the conversion tp PSI Pete.
You must have done the first one on your abacus and then decided to go to onlineconversion.com or one of those sites to get it right ![]() |
10-4,
Yes, the pressure will increase as the water is displaced by the air but only to the depth the barrel is pushed under water. IE: if you push the barrel 18 inches under water, the pressure in the barrel will be 18" water column. For those that prefer pressure in PSI, 18" of water column is .0.650291252 PSI |
Wouldn't the pressure in the barrel increase with weight pushing it under water when it is filled with air? Curious as to how much. Reason is that I am considering making a floating tiki bar using the same barrels. It will not be as heavy as a 2300 lb nautique sitting on them though.
Hi Joe,
I'll try my best to answer your questions. Here is a typical closure plug. Make sure your barrels have these type of plugs. As I said earlier, you may encounter trouble finding the correct ones after the fact; my experience is that each manufacturer has their own thread and overall diameter. ![]() As you can see, the center of the plug is threaded for 3/4" NPT. Simply drill out the center and tread in your adaptor. Each barrel typically has to bungholes. You need one of these plugs for each barrel. And you need one that hasn't been drilled out for the other bunghole. I used teflon tape to seal the treads on both bungholes plugs and the threaded adaptor(s). As you can see in the pictures of my lift, you will need to orient the barrels so that the plug with the pipe adaptor is at the 12 o'clock position. I used a commercial garden hose to plumb all the barrels together, because I'm cheap. A commercial garden hose is typically long enough to provide all the hose you need at a minimal cost, and they are typically quite UV resistant. I have no experience with the hose you mention, but my guess is that it is expensive and not very uv resistant. It might work, though. Relative to the holes drilled in the bottom side each barrel. I used a 2" hole saw, as I remember. Each barrel must be drilled, because if you don't there will not be a way for the water to be pushed out by the air. Same thing for lowering, there must be a way for water to enter each vessel. The size of the hole will be one of the controlling factors on lowering and lifting speed and control. You are right about the barrels near the front of the lift blowing out air before the rear ones. It is expected since the rear barrels are doing the heavy lifting since the front barrels are nearer the pivot point. No big deal, don't worry about that at all. Relative to the Unistrut or kindorf. I have only experience with the typical type used by electrical contractors. Maybe your BIL has some heavy-duty stuff in mind? I build stuff to last and would never consider using that stuff to build something like this. That's my opinion, and I would not want to offend you in any manner. I think that stuff is basically a toy. When you use the lift for the first time you will be amazed how much force the lift has to endure to pick the boat up. My guess it that to obtain the rigidity you ultimately need to prevent the lift from bending double you would need to use a lot of that stuff sam witched together in some configuration. Then think about wake wash from the lake, winter weather, storms, etc. To use substitute structural steel for the Unistrut is not going to add much to the cost, and may in fact be less expensive. The Unistrut Ive seen has a wall profile of about 1/8", it will not last under this type of stress. Finally, Pete is wise. I use a vacuum cleaner motor to provide the air. I am not an engineer, but I think a typical shopvac probably only generates a few PSI of pressure out the exhaust, You don't need a lot of PSI, only a lot of volume. One of those cheap shopvacs that the box stores basically sell as a door buster on Black Friday for $29 will work fine. |
All that's needed is about 24" (water column) so a turbine type blower can be used. |
It doesnt seem to be about pressure.. but rather volume.. not really pressurizing the drum other than to push the water out of the drain hole.. ive seen the big company or manufacturers Lifts.. their expensive poly tubes or floats use this same science of displacement. The way I see it.. These poly drums hold im some heavy heavy fluids and gels or soaps etc etc.. if the fittings hold that while being bumped, rolled, dropped and banged around.. they shoukd easily hold even a little air pressure haha.. I hope..
Page 12> |
