96 350 PCM water intake hose |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13513 |
Thanks(1)
Posted: October-03-2015 at 10:45pm |
Chevys and Commander Fords liked to use 1 1/4" raw water pumps. Nautique liked to install 1" through hulls. Your boat setup is likely factory. The logical place to make the change is the strainer. Through hulls rarely get changed. It's fine the way it is.
Strega51
Senior Member Joined: May-18-2014 Location: Windham,CT Status: Offline Points: 183 |
Supposedly the intake hose size for a 350 pcm is 1 1/4". But my 96 has 1" from the hull to the strainer than 1 1/4" to trans cooler. Is this right? If not than that would mean someone must have changed the thru hull ??
