  New Posts New Posts RSS Feed - Hull drain plug in or out?
cadunkle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cadunkle Quote  Post ReplyReply Direct Link To This Post Topic: Hull drain plug in or out?
    Posted: October-13-2015 at 5:14pm
Plugs always out when boat is on the trailer. Never know when something bad can happen. Even if mine was in an enclosed heated garage I'd still keep it plug out. I also keep doghouse propped open and shift seat base cushions to allow airflow under/around as much as possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2015 at 9:18am
I concur - in when no danger of filling with water and out when there is. Regarding filling with water, I have a friend with a 57 Century. Being a single plant hull, it must be soaked after a lay up to tighten up the planking. A common method is to put water in the bilge before putting it in the lake for the first time. If not soaked by ether running the hose in the bilge of by hanging in the water, they have sunk. Anyway, this friend had the hose going, went to work and his wife forgot to turn the hose off. Getting home, he found water coming out over the gunnels. The AMC 327 survived after several oil changes!
OldSchoolBlue84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolBlue84 Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2015 at 10:36pm
Originally posted by Hollywood Hollywood wrote:
If you're worried about critters I'd put a drier sheet over the plug hole with rock on top to hold it in place. It'll provide some blockage to critters but still somewhat drain in an emergency.
+1......I do this under a covered lean to protected by the elements.
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2015 at 10:20pm
Typically if my boat is on land/trailer plug is out, in/above water plug is in.
+1
'92 Correctcraft Ski Nautique
Cumby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cumby Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2015 at 5:09pm
Any chance your boat can fill up with rain or snow?.
It stays in storage, although it's a tin roof and I guess an occasional leak could be possible. Sounds like a good idea to put dryer sheets in the drain with something heavy over it.
99 Ski Nautique GT40
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2015 at 5:00pm
When in doubt, pull it out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2015 at 3:47pm
Any chance your boat can fill up with rain or snow? Typically if my boat is on land/trailer plug is out, in/above water plug is in.
C-Bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2015 at 3:42pm
I take mine out only if it needs drained. At that point it's only out long enough to let the water drain out then it goes right back in. Don't know why it would hurt to stay in?
Craig
67 SN
73 SN
99 Sport
85SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cumby Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2015 at 3:08pm
Is it bad to leave your drain plug in for the winter? I've always left it out but wonder about the possibility of visitors coming in from the cold?
