  New Posts New Posts RSS Feed - Removing 88 Ski Nautique for trailer rebuild
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Topic: Removing 88 Ski Nautique for trailer rebuild
    Posted: October-11-2015 at 10:47pm
Wet sanding and polishing will help but they may always be there,just put on new decals and you'll be ok. N3 one of the sites sponsors will have the decals,Zach the parts manager is a regular here too.
Chadrik232 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chadrik232 Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2015 at 10:00pm
Are the 2x4's nailed together?
Also any tips on finding lettering that would be an exact match to what was originally there so you don't see where the original stickers were? or will just cleaning the boat up make them not as visible?
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2015 at 9:45pm
If you use concrete blocks, make sure the cores are vertical orientation.
CrazyCanuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrazyCanuck Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2015 at 5:57pm
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrazyCanuck Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2015 at 5:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2015 at 5:29pm
Chad,
The trailer removal wasn't my idea. It's been used for years. I learned how to do it way back at a marina. Concrete blocks topped with some scrap wood and then some carpet scraps is what I've always used.
Nice 88. Besides having the trailer done, you could do a wet sand and buff. Great winter project. Explore the site. There are fantastic links to member threads in the FAQ topic located in the maintenance section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chadrik232 Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2015 at 5:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chadrik232 Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2015 at 5:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chadrik232 Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2015 at 4:33pm
Didn't think about that good idea any thoughts on what to use to block up the boat? By the way Go Pack Go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2015 at 4:27pm
Chad,
You're getting too complicated with the lift! Lower the tongue as much as you can. Block the aft end of the boat at the two corners near the transom. Raise the tongue as much as you can. Block the keel near the stem. The boat should now be off the trailer. Move the trailer forward until a cross member comes to the blocking at the keel. Re position the blocking aft of the cross member. You may need to do this several times before the trailer is free.
Welcome to CCfan. How about some pictures. We always enjoy them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chadrik232 Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2015 at 4:16pm
I want to remove my 88 nautique from the trailer to sand blast repaint and redo the whole trailer. I was thinking of using a engine lift in the back and front end loader in the front then pull out the trailer, but not really sure what to set the boat on in storage. Would like any tips that you guys have due to the trailer rebuild isn't worth it if I mess the boat up.
